Pre 84 Trucks 1st gen pickups
Trucks pulls to the right under breaking.
Old Dec 21, 2020 | 04:10 PM
nottoshabi's Avatar
5 Year Member
The truck is starting to pull to the right on the freeway when I break. Its not that bad right now but it will get worse soon. I have had this issue before on a different vehicle and this is the first sign of the caliper going bad. RockAuto has some calipers for sale for this truck and I was wondering if any of you guys ever changed your calipers and which ones did you get?
Old Dec 23, 2020 | 09:50 AM
slacker's Avatar
is it consistent on every road ? because , some roads have "ruts" or "ridges" from heavy traffic
Old Dec 23, 2020 | 02:47 PM
nottoshabi's Avatar
5 Year Member
@slacker Its consistent.
Old Dec 23, 2020 | 02:54 PM
slacker's Avatar
jack the front end up , and see if the caliper is dragging .... I would then suspect you are correct in your assumption .
Old Jan 5, 2021 | 04:35 PM
nottoshabi's Avatar
5 Year Member
Found why the truck was pulling to the right. This is the drive side caliper, as you can also see the break pad on that side is also a slight bigger. It started acting like this only for a month or two, if I would of not change the caliper the difference in break pad wear would of been drastic and would destroy my alignment.
HiluxSurfGuy
Jun 29, 2020 11:59 AM
Lunnzz
Sep 20, 2011 07:42 PM
FleshThorn
Apr 7, 2011 07:31 AM
Byrdmen
Mar 16, 2007 04:05 PM
Godzilla
May 31, 2005 01:39 PM
