Pre 84 Trucks 1st gen pickups
Tacometer wiring 1977 pickup
Old Aug 19, 2025 | 12:58 PM
Rowan1's Avatar
Just pickup up a long bed 5 speed 1977 for 1500 I got a tachometer for it and am having trouble with the signal wire if I run it off the negative pole on the coil the tach reads 8k constantly (the max it reads) so im just wondering what what the right place to get tach signal is. Also I saw on a 88 some guy on a forum said to run it off the green wire on the igniter assembly and that also did not work.
Old Aug 20, 2025 | 07:04 PM
81 4X4's Avatar
Do you have the tach set to a 4 cylinder? When I put a tach in my 81, here's how I wired it. Typically, you'll connect the red wire to a switched 12V power source, the black wire to ground, the green wire to the negative side of the ignition coil, and the white wire to the parking/headlights for illumination.What color wires does your tach have? I think they all should be the same colors regardless of brand. I would definitely check that you have a good ground.
Old Aug 20, 2025 | 07:54 PM
Rowan1's Avatar
yea i had it set to the 4 cyl mode same exact wiring as yours ill try and put it on a better ground and see if that makes a difference it's also a 25 dollar tack from ebay so that couod be the problem
Old Aug 21, 2025 | 02:06 PM
81 4X4's Avatar
I think I bought my tach from O'Reilly auto parts. Yes the $25.00 tach could be the problem. The one I bought from O'Reilly wasn't very expensive.
Old Aug 21, 2025 | 05:31 PM
Rowan1's Avatar
yeah thanks man that was the problem i bought one from autozone to check and it worked perfectly ebay junk gonna return the autozone one and get a glowshift one though cause it fits better in the hole I made on the dash
red90toyota
Mar 28, 2017 06:03 PM
az1320
Nov 12, 2016 10:01 PM
ashamsuddin
Oct 16, 2015 04:55 PM
sirhk100
3.4 Swaps
7
Apr 14, 2011 08:11 AM
943kgt
Jan 17, 2007 01:41 PM
