Pre 84 Trucks 1st gen pickups
Stock shock mount HELP
Old Nov 3, 2014 | 12:04 PM
83Yota crawler's Avatar
I need to know the width of the stock lower shock mount
I have shocks the are 1.5" the shock mount is only 1.25"
Old Nov 3, 2014 | 04:55 PM
slacker's Avatar
I think you mean length not width .. right ?
Old Nov 3, 2014 | 08:59 PM
The front lower mount width
Old Nov 3, 2014 | 11:58 PM
wyoming9's Avatar
Red face
It is not the shocks but the bushings.
You have 2 choices trim the bushings down to fit in your brackets.
I have done this over the years on shocks that fit several applications
Number 2 make new brackets and weld them on.
Old Nov 4, 2014 | 08:07 AM
kawazx636's Avatar
With that much of a difference in mounting tab width, I wouldn't recommend trimming the bushings. You could, but it wouldn't leave you with much bushing left between the shock and the mount. If you can't return the shocks and get the right ones, then I would go with option #2 like Wyoming said - weld on new brackets. It's pretty simple to do yourself if you can weld, or any metal shop should do it for next to nothing for you.
What brand shocks are you trying to install? And how much lift do you have? I likely have some part numbers for Bilsteins, Old Man Emu and Ranchos if you are looking to find the appropriate shock.
Old Nov 4, 2014 | 04:32 PM
slacker's Avatar
a ha, I was thinkin rear .....
you may also try spreading the mounts
Old Nov 5, 2014 | 12:31 PM
I got the shock installed i decided to cut the bushing down to the same width as the metal sleeve that goes inside them
Attached Thumbnails Stock shock mount HELP-image-2867238709.jpg   Stock shock mount HELP-image-482495158.jpg
Old Nov 6, 2014 | 06:42 AM
kawazx636's Avatar
That'll do!
Yotadawgjr
10
Aug 23, 2015 10:51 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
garagespace
Jul 9, 2015 08:37 AM
