Pre 84 Trucks 1st gen pickups
replace
Old Aug 8, 2008 | 08:47 AM
bruzryoda's Avatar
replace
i will b replacing the worn front axle seals on my 81 4bi. what i am concernd about is what kind of grease to use for packing the bearings. i was going to use high temp. wheel bering grease. but being this is my first toyota 4x4 i would like to know. and i also herd these seals r a pain to replace. true or not??
Old Aug 9, 2008 | 08:28 AM
dropzone's Avatar
Fossilized
not sure about the grease type but the rebuild process will be the same for any 79-85 toyota axles. Here is a link to a 58MB download for an '85 Truck Service manual, you will find the seal replacement procedure there
http://www.ncttora.com/fsm/index.html
Old Aug 18, 2008 | 08:06 AM
trbizwiz's Avatar
My wheels dont wiggle, but when I replaced my manual hubs with warn manual hubs there was quite a bit of play in the axel coming through the hub. Does that sound like worn berings, or is that normal?
Old Aug 21, 2008 | 03:17 AM
dropzone's Avatar
Fossilized
not normally, sounds like you screwed something up on your install (besides replacing Aisin Hubs with Warn Hubs). Depending on the mileage of your truck, how many water crossing etc it probably would be a good idea to order a front end service kit from some place
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
