Pre 84 Trucks 1st gen pickups
Rebuilt engine burning oil
Old Nov 20, 2013 | 06:39 AM
HighLux's Avatar
Time for a compression test
Old Nov 20, 2013 | 06:42 AM
Ol'Greeny's Avatar
If it was rings though wouldn't I have blow by out the valve cover? And it would be smoking more on hard acceleration?
Old Nov 20, 2013 | 07:48 AM
kawazx636's Avatar
Your best bet would be to post a picture of said smoke. You may be over exaggerating about something that could be normal
Old Nov 20, 2013 | 07:59 AM
HighLux's Avatar
Takes all of 10 minutes to do the compression test and rule out the rings.
Every man should own a compression tester. Go buy one right now. Even a harbor freight cheapie if you must. I use a craftsman one. Served me well.
Its not always about just finding out what the exact wrong thing is...its about ruling things out process of elimination.
Smoking on decel makes my "rings" alarm go off. We eliminate the rings...then we look at valve seals...and guides.
Help us.....help you.
Old Nov 20, 2013 | 01:56 PM
  #25
Ol'Greeny's Avatar
I'm not sure I can get a picture. I took some video on my drive home. But it won't let me upload the good one.
Old Nov 20, 2013 | 02:07 PM
  #26
Ol'Greeny's Avatar
It's a thicker cloud at highway speeds.
Old Nov 23, 2013 | 01:15 PM
  #27
Ol'Greeny's Avatar
I jut checked compression. Each cylinder was 150psi. Does this point to valves then?
Old Nov 23, 2013 | 03:49 PM
  #28
Ol'Greeny's Avatar
Anyone?
Old Nov 23, 2013 | 03:55 PM
  #29
HighLux's Avatar
Valve guides. Your compression is ok. Not great for a brand new motor though. Your valves are working.
The guides didnt get done or were done wrong....and oil is leaking past burning.
I'd be talking to the builder by now.
Old Nov 23, 2013 | 03:58 PM
  #30
Ol'Greeny's Avatar
I'll have to give them a call Monday. But with valve guides wouldn't it smoke on start up, or after idling for a few minutes too? Thanks for the help.
Old Nov 23, 2013 | 04:04 PM
  #31
HighLux's Avatar
valve seals ...smoke at startup
valve guides while running...
Old Nov 23, 2013 | 05:19 PM
  #32
Ol'Greeny's Avatar
Must be guides. Is there any way something else could be causing smoke between shifts and decel(high vacuum) besides the guides.. It was smoking the exact same way before the new engine too.
Old Nov 23, 2013 | 06:38 PM
  #33
HighLux's Avatar
Time to see if the builder is a stand up guy or not.
Old Nov 24, 2013 | 08:37 AM
  #34
83's Avatar
83
It was time to check on that weeks ago when he first posted about it here and we suggested it...
But yeah, better late than never.
Old Nov 24, 2013 | 08:44 AM
  #35
Ol'Greeny's Avatar
I've called them twice. He's told me to let it break in all the way and get a few thousand miles on it. I don't see too much point in calling since I installs it my self and don't have a warranty.
Old Nov 24, 2013 | 08:49 AM
  #36
HighLux's Avatar
You are saying there is no warranty on the engine unless a shop installs it?
Why would you even buy a motor with no warranty? price?
Its worth a shot to see if they will stand up. Bad valve guides can hardly be blamed on installation.
Old Nov 24, 2013 | 08:52 AM
  #37
gillesdetrail's Avatar
In the first moments of life of the motor, did you free-rev it a lot? Did you drive really smoothly at low load and rpms and at constant speeds for long periods of time? Did you use good quality synthetic oil? All of these things could have screwed the break-in process. It is important to have the rings expand and contract for them to seat properly i.e high loads and then let it compress, also to use conventional oil (less ''slipery''). How many times have you changed the oil and at what inervals?
If I was you, I would drive the thing hard for a while, like floor it in second and let it compress in third, then floor in third and let compress in fourth, and repeat that process a couple of times, but your problem could also have nothing to do with the piston rings not seating properly.
Old Nov 24, 2013 | 09:11 AM
  #38
83's Avatar
83
Ah, I never saw that you mentioned talking to them.
Not many rebuilders do installs...they aren't general mechanics, they're engine rebuilders. Most rebuilt engines are installed by someone other than the rebuilder, and come with a warranty.
But that's good that you've been in contact with him and have documented what might be issues.
Old Nov 24, 2013 | 10:21 AM
  #39
Ol'Greeny's Avatar
I followed the break in procedures. Used 10w30 oil. Not synthetic. I didn't keep it at low rpms. I drive it like an 18 year old should (didn't abuse it) but didn't baby it. I had the exact problem before the new engine.. Which makes me think it's not the rings or valves. As I was adjusting the carb today I noticed as I backed out the mixture screws it was smoking whitish with maybe a hint of blue. And I could change the amount of smoke at idle with mixture. And when I shift higher rpm on the highway when it smoke it's seems like it's a white smoke that turns light Blueish.. Is this a problem with my carb? Me and my grandpa are starting to think it is.(again) the whitish smoke is not from coolant or condensation.
Old Nov 24, 2013 | 10:23 AM
  #40
Ol'Greeny's Avatar
My grandpa also says driving behind me the smoke smells like fuel
