Pre 84 Trucks 1st gen pickups
re tapping exhaust manifold holes
Old Jun 22, 2012 | 07:21 PM
foolio's Avatar
I have a 1980 4x4 with a 1981 22r. I had a bad exhaust leak and went to replace the gaskets. The previous owner of the truck decided to only use 3 bolts to fasten the exhaust manifold instead of the 9 you are supposed to use. On top of that he used 3/8 bolts instead of metric so now the threads are ruined. Anyway i was wondering how difficult it might be to make the holes bigger and re tap them. or if there is any other option. thanks
Old Jun 22, 2012 | 09:28 PM
nothingbetter's Avatar
use a helicoil. Simpily put, you drill out the old threads, tap with a special tap they include, thread in an insert, then put your new bolt in. Better than new? I just bought a M10x1.5 set for $65 cdn. It included the special tap, 12 inserts, the insert threader and clear instructions on how to use it. You supply the drill and bit.
Make sure you oil the tap a few times while cutting or the aluminum will clog the bit and wreck your newly cut threads.
Old Jun 22, 2012 | 11:20 PM
gmack192's Avatar
Originally Posted by nothingbetter
use a helicoil. Simpily put, you drill out the old threads, tap with a special tap they include, thread in an insert, then put your new bolt in. Better than new? I just bought a m10x1.5 set for $65 cdn. It included the special tap, 12 inserts, the insert threader and clear instructions on how to use it. You supply the drill and bit.
^^^this^^^
Old Jun 23, 2012 | 01:05 AM
wyoming9's Avatar
Wink
Heli-coil is just one of several thread inserts i think they may have been the first.
Just so you know the proper size for those holes is M10 x1.25
I really don`t know if I would want to repair that many holes without taking the head off.
Old Jun 29, 2012 | 01:52 PM
foolio's Avatar
thanks guys ill tell you how it goes when i get a chance to put a header on. Someone told me when i do a helicoil i should throw studs in there instead of useing bolts so i dont have to deal with the freezing issue.
Old Jul 1, 2012 | 07:18 AM
I havn't heard of issues with "freezing" A bit of anti sieze and I figure I'm good to go.
I had issues finding 10x1.25 helicoil packs and the bolts to go with it. I just used 10x1.5 as I could get those in town. All the old threads are drilled out and your starting from new anyways.
Old Jul 1, 2012 | 07:24 AM
wyoming9's Avatar
Wink
Being your in the Wilds of Canada I could see you have a problem getting anything .
I had no problem getting the right size the price one has to pay leaving only 100 miles from the rotten apple:wabbit2:
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
romex1
Aug 10, 2015 06:21 PM
accuracy
Aug 6, 2015 12:32 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
