Pre 84 Trucks 1st gen pickups
Oil Leak
Old Feb 17, 2011 | 12:21 PM
sagorski1611's Avatar
Oil Leak
I fired up the yota this morning and let it run for about 5 minutes and noticed that it was leaking oil around the fan at a good rate. When I popped the hood it was all over the belts and the fan. Here is pic of where it looks like it it coming from. Everything is covered so it is hard to pin point. Any Ideas?
Thanks
Old Feb 17, 2011 | 01:44 PM
Gov't Mule's Avatar
Yikes....timing chain cover is the first thing I'd look at, as well as the front crankshaft seal and oil pump O-ring gasket.
Old Feb 17, 2011 | 04:09 PM
Teuf's Avatar
So this leak is new, when was the last time you looked under the hood.
Old Feb 17, 2011 | 04:44 PM
I know this isn't a new leak, I look under the hood every day when I bring the battery in for the night so that it doesn't drain at -40. I tried to clean most of the oil up to get a better idea of where it was coming from. After firing it up again, it looks to be coming from around the oil pump. Looks like I have my work cut out for me.
Old Feb 17, 2011 | 05:56 PM
Teuf's Avatar
Keep us posted on your journey, pics would be cool.
Old Mar 1, 2011 | 08:55 PM
ToyoTech559's Avatar
work? its so easy to do. 1st time i done one was last week.
1: take your belts off
2: take your crank off
3: take your oil pump off
4: change o-ring and crank seal
5: reinstall
6: done
dont even need to lift the truck, i did cuz i did it at work lol
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
