Pre 84 Trucks 1st gen pickups
new cylinder head on 4g64 sohc 16v mitsubishi
Old Dec 20, 2017 | 04:27 PM
Riptus's Avatar
Just put a brand new complete cylinder head on a 2.4l efi 4g64 16v sohc engine.
Changed oil filter and all gaskets, timing belt kit, water pump and hydraulic tensioner. all done to spec by a mechanic. Seems to be a lot of ticking from the engine...sounds a bit like a diesel. Timing is spot on, no smoke, engine revs free and good lotsa power. Concerned about the ticking. Mechanic said to take it for a long drive on the highway....thoughts?
Old Dec 20, 2017 | 04:46 PM
millball's Avatar
Thoughts???? You shoulda bought a Toyota.
This Is a Toyota forum, after all.
Old Dec 27, 2017 | 09:32 AM
jakey poo's Avatar
Sounds like you need a turbo and a 4g63
Old Dec 28, 2017 | 06:04 AM
L5wolvesf's Avatar
Toyota 1 (Billion) -- Mitsubishi Zero
Old Dec 28, 2017 | 06:56 AM
muddpigg's Avatar
You should introduce yourself in intro section and post pics of your rig.
Old Dec 28, 2017 | 06:12 PM
Thommo Thompson's Avatar
i have the 4g63 myself, pilr of junk design with the carb. if its ticki g after a head change that would probably be due to the rocker arms needed to be gapped again. anytime the head is off, this needs to be done.
just pop the rocker cover and check theyre all in spec. really ur mechanic shouldve done it, but its likely it wasnt included in the quote.
Old Dec 28, 2017 | 06:16 PM
actually sorry theyre hydrualic lifters arent they. no adjustment possible.
if a good drive hasnt sorted it, there may be a problem with a lifter or an oil channel :/
Fink
Jan 30, 2010 03:40 PM
scottrod2
Jul 7, 2009 09:41 PM
bruteforz05
Engine Swaps
Dec 20, 2008 01:09 PM
Bumpin' Yota
Aug 31, 2007 07:58 AM
dr3wstar
9
Mar 22, 2005 02:17 PM
