Pre 84 Trucks 1st gen pickups
Is my transmission screwed? (video)
Old Nov 26, 2015 | 08:00 PM
gillesdetrail's Avatar
L52 transmission
Look at the teeth on my 5th gear, can I even drive that? Can I swap the lower .790 gear from the ax-15 jeep transmission (heard they were similar)?
Is the play on the input shaft normal? What about the fact that the bearing is not tight in the casing? What do you guys see wrong here? Thanks.
Old Nov 27, 2015 | 05:02 AM
dropzone's Avatar
Fossilized
never heard of the AX15 being close to an L-52. It is somewhat compatible to an R-151(or R-150, forget which)
I wouldn't drive with that chipped gear.
Good luck
Old Nov 27, 2015 | 03:52 PM
Yes with more research I realise they are not that similar, and I did get a bit mixed up with the ax5, but they do have some things in common like gear ratios (ax5/l52), bell housing-to-body bolt pattern (ax15/w-series and/or other) so maybe just maybe it could be possible? Why could have caused those chipped tooth you think?
Old Nov 28, 2015 | 01:15 PM
By the way, is my chipped gear 5th gear? I assumed it was, but after taking the rear section off there is another gear there, can anybody confirm?
Old Nov 28, 2015 | 05:28 PM
Which gear is this?
Old Nov 30, 2015 | 07:29 AM
kawazx636's Avatar
I'm just along for the ride here. I may be replacing the input shaft bearing in my L52 soon too...
Old Nov 30, 2015 | 07:00 PM
I think the gear that I have that is chipped is actually my input shaft, and the gear is part of it.
So I'm trying to tear appart my l45 4 speed to use the input shaft using this thread: https://www.yotatech.com/forums/f114...ission-241408/
But having a hard time with the terminology and I am stuck right now, will figure it out tomorrow. What I found out is that my l45 feels MUCH tighter when spinning and half as much up/down movement on the shafts
TheChunknorris
Feb 19, 2018 12:30 PM
Elow007
7
Dec 4, 2015 02:12 PM
Elshaunero
Engine Swaps
Nov 30, 2015 11:28 AM
delmert
Nov 25, 2015 04:34 AM
