Pre 84 Trucks 1st gen pickups
I've reached the end of the internet
Old Mar 7, 2017 | 05:09 PM
flg8r22's Avatar
Here's the issue I'm having. 1980 RN47 L43 side shift trans. The shifter is so sloppy I have to hang out the passenger side for the top gears. I've looked at Marlin, 4x4 wire etc and can't find the bushing (s) I need. I have several newer 5spd trans but I want to keep this one in the truck. My FSM is for an 81 and doesn't cover the L43. Thanks in advance for any help.
Old Mar 8, 2017 | 08:19 AM
dropzone's Avatar
Fossilized
you may try giving Marlin a call. For some reason I seem to remember them having a limited supply of bushings that wasn't on their site.
Old Mar 8, 2017 | 08:36 AM
flg8r22's Avatar
Thanks Robb. Unfortunately I tried them last eve. They're out. My search continues
Old Mar 8, 2017 | 08:47 AM
dropzone's Avatar
Fossilized
someone had a source recently, i'll see what I can find..i feel your frustration, i have friends that do restorations that like to keep the parts as stock as possible..
Old Mar 8, 2017 | 10:22 AM
flg8r22's Avatar
Thanks man. I appreciate your help.
Old Mar 8, 2017 | 04:53 PM
thechief86's Avatar
I've had decent luck checking with machine shops for random bushings, and even having them made, or making my own when I had access to a lathe myself. The only issue is that you need dimensions, as far as length, inside diameter and outside diameter, as well as knowing what you want them made out of. I've been known to use aluminum and bronze and brass in place of nylons and hard rubbers.
Old Mar 8, 2017 | 05:34 PM
flg8r22's Avatar
Man that's not a bad idea. I've got a CNC machine at the shop I can blow the dust off of and give it a shot. Maybe the dealer will have the specs. Thanks!
