Pre 84 Trucks 1st gen pickups
Intake question
Old Aug 3, 2013 | 07:49 PM
gmack192's Avatar
Intake question
Quick question, and I hope I get the answer I am looking for.. Will my Offenhauser intake fit the 85-95 head?
I think it will but need to be sure.. Most of the engines I find say 85-95, mine is a 83.. I know the deck height is slightly different..
Old Aug 3, 2013 | 07:58 PM
gmack192's Avatar
I looked on Summit, they say 81-90. But also say "Engine Block Style:Stock/OEM standard deck" And that is why I am confused...
Old Aug 5, 2013 | 09:07 PM
kawazx636's Avatar
I'm almost certain that it will. The reason why it may not cross reference is because most 85-95 heads are EFI. The offy should fit a 84-85 carb and I'm pretty sure that the heads are the same from 84-95 regardless of Carb/EFI. Maybe check with Ted from Engnbldr - he would definitely know.
Old Aug 5, 2013 | 09:23 PM
abeD85flatbed's Avatar
as long as you are running a 22R and not a 20R it should work. The 20R had round intake runners and the 22R had rectangular, other than that the intake mounting surfaces didn't change. Sometimes you have to run a different thermostat housing depending on fuel pump clearance issues when you change intakes.
Old Aug 5, 2013 | 11:09 PM
gmack192's Avatar
Thanks Guys...I am sure it will, (HOPE so any way) I ordered the engine last night..
A NEW 22R from Japanengines.com (not rebuilt) for $1750 delivered... I will post how it does in the future..
Blamalam
Mar 12, 2022 07:34 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
