Pre 84 Trucks 1st gen pickups
I have a theory (white smoke)
Old Mar 14, 2014 | 09:25 AM
craftsmanracer's Avatar
As to why my engine is smokin up a storm intermittently.
I think it could be a completely ruined valve stem seal.
It smokes on startup without a doubt, but when I restart it when it is hot sometimes it is just a little bit of smoke, and sometimes it tries to black out the sun.
here is a little bit of smoke example:
[YOUTUBE]
[/YOUTUBE]
And here is the eco-nonfriendly version
[YOUTUBE]
[/YOUTUBE]
The smoke goes away after driving for about 2 mins.
But is has used some coolant.......and was on the verge of overheating on last night's drive.
SO it could be a head gasket too.
Old Mar 14, 2014 | 10:02 AM
gillesdetrail's Avatar
From what I can see from the video, it is definately water realated, since it looks like condensation and the smoke clears up real fast. If it was valve stem seal, it would be blue smoke but also much thicker, it wouldn't thin out in the air like it seems to do in the video. I 'm thinking head gasket too but to make sure you can do a leak down test and also there are testers you can use with your coolant to see if there are traces of exhaust gas.
Old Mar 14, 2014 | 10:25 AM
vital22re's Avatar
totally a bro
I'm fairly sure its the head gasket. Also it sounds as if its missing.
Old Mar 14, 2014 | 11:55 AM
ok cool, I figured it was a head gasket after thinking about it for a while. I went and got the parts, gonna try and do the gasket today.
Old Mar 15, 2014 | 05:07 PM
kawazx636's Avatar
Valve seals wouldn't be blowing white smoke. It would be blue and would typically disipate after it warms up because the valve seals will lube up and expand to hold back oil.
If you're over heating and losing water then I would say that you have a coolant leak issue
Old Mar 16, 2014 | 05:52 PM
did a headgasket over the weekend, easiest one I've ever done on a car. Hardest part was getting the cam gear back onto the camshaft.
Now it runs like a champion, alot smoother.
Although, the old gasket that was leaking was a fel-pro, and I installed another fel-pro. Hope it lasts for a while, I didnt have time to wait on a toyota gasket.
Old Mar 16, 2014 | 06:48 PM
HighLux's Avatar
Head gasket.....hell damn thing is missing in the video. She is a goner. Get to ordering some parts and bustin some knuckles.
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
1985 4Runner
Sep 30, 2015 10:17 AM
charlie_fong
Sep 27, 2015 10:06 PM
Buckaroo_Banzai
Sep 24, 2015 07:26 AM
