Pre 84 Trucks 1st gen pickups
Herculiner
Old May 28, 2008 | 08:53 PM
camo31_10.50's Avatar
Herculiner
anybody know about how much herculiner it will take to give my shortbed on my '80 a good coat on the inside...just the bedliner is all im doin...the floor of the bed..and the sides...thanks...i know it takes like 1/2 gallon i think to do the cab...thanks for the info
Old May 29, 2008 | 04:50 AM
dropzone's Avatar
Fossilized
the one gallon kit should do it. key is getting a good lasting finish is all doing the prep work correctly.
Old May 29, 2008 | 05:45 AM
dirtoyboy's Avatar
Yes...that is key...the prep... I spent days prepping mine. Clean everything with Xylene before using and dont get it on your hootus.
Make sure you put a good 3 or 4 coats where your feet sit under the pedals (this area recieves the most wear on your floor) A gallon MIGHT be enough.....I think you might need a gallon and a quart or so for adequate coverage.
If you havent already purchased check out a product called Durabak...its some tough stuff
northfacer581
60
Oct 28, 2008 10:41 AM
E-money
Jul 18, 2008 07:41 AM
97Runner
Apr 8, 2007 02:12 PM
Mountainmanic
Oct 1, 2006 04:16 PM
