Pre 84 Trucks 1st gen pickups
HELP!!!(oil pan gasket)
Old Dec 22, 2007 | 01:35 PM
camo31_10.50's Avatar
im in the process of the oil pan gasket on my 80' Yota....its a PITA ....it will NOT COME OFF!!...at all...none...wont even hardly budge...i knopw its glued on there...but i cant even get it to budge..any advice would be GREATLY appreciated..as i have to have this done TODAY!
Old Dec 22, 2007 | 02:06 PM
86tuning's Avatar
small hammer and a putty knife, tap it in, and then use the knife to seperate the pan from the block.
I've never worked on an '80 before, but the current Toyota cars and trucks all use FIPG (silicone sealant) to attach the oil pans.
Cheers!
Old Dec 22, 2007 | 02:26 PM
INFINITY's Avatar
Cheers!
bingo!!
on my 80 this is what i had to do and yes it was a big pita. the gasket is cork which hardens like epoxy. good luck and dont bend the pan
Old Dec 22, 2007 | 02:35 PM
Icarus's Avatar
Exclamation a little heat
try to warm gasket surface.at work i use torch kept at distance,but for safety sake you might try heat gun.
Old Dec 22, 2007 | 05:07 PM
lenwood's Avatar
get a can of parts cleaner,that stuff eats through everything,then let it sit and very carefully try that putty knife
Old Dec 22, 2007 | 05:16 PM
CJM's Avatar
CJM
Gum cutter, its made to eat that stuff off.
Old Dec 22, 2007 | 05:43 PM
thanks guys...after a little while of prying...squirting...soaking...and a few choice words my dad and I finally got it off...thanks for the quick advice!
Old Dec 23, 2007 | 12:15 AM
deserttoy84's Avatar
just make sure you DONT use those stupid cork gaskets when you put the pan on. Go to any toyota dealership and ask for Oil pan gasket maker(silicone). Run a bead around the whole pan and then tighten up all the bolts to 9 Ft lbs in a cross pattern. Let it sit for at least 24 hours(longer the better) then youll be leak free.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
