Pre 84 Trucks 1st gen pickups
front spring mounting
Old Apr 27, 2009 | 11:19 AM
jaredandlindsay's Avatar
i have some 3" front shackles and was wondering if anyone has ever put shackles in the front to get rid of excessive driveshaft angle. i have 4 or 5 inch lift leafs. the shaft doesnt' make any noise from it being to much angle. and not eating up u joints yet. but i just was looking at a cj the other day and noticed that they have shackles in the front. this would help eliminate excessive shaft angle wouldn't it?? just curious to see if anyone has ever done this.
Old Apr 27, 2009 | 12:00 PM
4banginRunner's Avatar
Wait...so you want to put shackles on the front of the front springs like a CJ?
Old Apr 27, 2009 | 12:28 PM
yotaboy82's Avatar
front shackles = EWWWWWWWWWWWWWWWWWWWW
Old Apr 27, 2009 | 01:26 PM
Al's Chop Shop's Avatar
your shackles are in the back, not the front. if you put shackles in the front too, you'd be up for one hell of a ride!
Al
Old Apr 27, 2009 | 02:00 PM
Al
x2, it'll be unsafe as all hell, it'll allow the front axle to move around as it pleases
then we'll be forced to throw you in with the spooky suspension and steering archives
Old Apr 27, 2009 | 02:42 PM
dropzone's Avatar
Fossilized
Vehicles with front mounted shackles tend to wander a bit when driving., probably why they make front shackle elimination kits for the front of old jeeps.
if your lift the front spring mount too much you run the risk of not allowing your front end to turn correctly, take a look at the trunion bearings on the front end of a toyota straight axle
(borrowed from slacker's Trekker thread, THanks Corey)
These pic's show how the steering knuckle pivots on the ball, turn those pivots too far forward (past the perpendicular) and you won't people to turn correctly.
In the quest for the perfect pinion angle on the front driveshaft some people with go to the extent of cutting and turning the front end. Go that route you had better know what you are doing.
ANother option-Hi Pinion third member-only recommended for the front, expensive.
-High Angle Drive shaft- cost any where from $300-800.
I would not worried about your front DS angle just yet, if your suspension is somewhat flexible like mine I would be more worried about having enough spline contact in the slip yoke..
hope this made sense
Old Apr 27, 2009 | 02:45 PM
dropzone's Avatar
Fossilized
random thought:
As Al and 4bangin said, if you ended up with shackles on both ends of the spring (has been done) the springs would go where ever they wanted, than you would end up needed some form of links and panhard bars to keep the axle correctly centered--go that route might as well 4 link it
Old Apr 30, 2009 | 08:57 PM
4x4YOTA's Avatar
use degree shims to correct it
Old May 7, 2009 | 07:55 AM
yea ocdropzone that makes sense. i just had seen an old jeep with front shackles and rear solid mounts, and i just figured since my truck came with 3" front shackles, it makes my d/s angle pretty bad. i'm thinking i'll just find some stockers to put in place. and to all you others who thought i'd have shackles in the front and rear of the front springs. lol!!! whoever would think of doing that. ohhh my!!!!!!
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
toyoda8488
Jul 5, 2015 10:18 PM
