Pre 84 Trucks 1st gen pickups
Front drive shaft problem!!!
Old Jan 19, 2009 | 09:28 PM
toyabro's Avatar
hi, just joined the fourm.i have a 1981 yota long bed 4x4 i just put in a rough country 3" suspension lift and having problems with the front drive shaft what do you guys do to it to make it work.it looks like its coming half way off. i tried putting a spacer in the front part where the axle is but, on the end of the drive shaft where the transfer case is it hit where the joints are to much of a angle. was wonder if anyone can help me with this problem.
Old Jan 19, 2009 | 09:37 PM
algranger's Avatar
does it have one of these (double cardon joint) ...maybe its cardan but i donno
the double cardon will allow a lot steeper angle it goes on the end with the tcase.
also consider making a square driveshaft. if you have a double cardon you could increase its abilities by grinding some stuff down inside
Old Jan 19, 2009 | 09:45 PM
toyabro's Avatar
its has one but it looks like i need a spacer or something? i can see the thread in the shaft.
Old Jan 19, 2009 | 09:50 PM
algranger's Avatar
a spacer? i'm not followin ya... got any pictures?
Old Jan 19, 2009 | 10:11 PM
SpecialScottie's Avatar
A spacer would make the angle steeper
Old Jan 19, 2009 | 10:27 PM
dubud07's Avatar
with 3inches your havin this proble? i have around 6 or 7 maybe a little more and i have never had to worry about it. th only difference is a got degree shims in the front springs to bring my pinion up alittle bit
Old Jan 20, 2009 | 03:02 AM
scooper's Avatar
Do us a favor and snap a picture of your underside for us. Preferably between the T-Case and front axle. I have broke and ripped apart many yota drive shafts and have never heard of a stock one having problems like that with only a 3" lift. I have seen 6" lifts on them and still they worked perfect. I think someone has done something wrong or "modified" it incorrectly.
Old Jan 20, 2009 | 11:01 AM
toyabro's Avatar
here are so pic'sName:  PIC_0588.jpg
Old Jan 20, 2009 | 11:03 AM
toyabro's Avatar
http://i168.photobucket.com/albums/u...l/PIC_0582.jpg
Old Jan 20, 2009 | 11:04 AM
toyabro's Avatar
Old Jan 20, 2009 | 11:06 AM
toyabro's Avatar
Old Jan 20, 2009 | 11:53 AM
yotaboy82's Avatar
LOL....first of all...you put your drivshaft on backwards
Old Jan 20, 2009 | 12:08 PM
Flek23's Avatar
Yup...that'd be it. Just curious though. Is Your steering linkage hyper-extended like that too?
Old Jan 20, 2009 | 12:28 PM
dropzone's Avatar
Fossilized
x23 on the shaft being installed backwards, the DC joint should be at the transfer case. If you are still having issues with the shaft being too short, it looks like a fairly new shaft. Take truck to a driveshaft shop and have them lengthen your current one, though with that mild of a lift flipping the shaft should fix it.
Old Jan 20, 2009 | 12:31 PM
scooper's Avatar
Nailed it on the head guys, good call.
Old Jan 20, 2009 | 04:19 PM
slacker's Avatar
... NOOB!!! ....
welcome aboard !! we're all here to help .
thank GOD you didnt post this on Pirate !!!
Old Jan 20, 2009 | 04:22 PM
algranger's Avatar
double cardon goes up by the tcase. how deep does that spline go in?
Old Jan 20, 2009 | 04:32 PM
86Toyrunna's Avatar
yikes Slacker is right.. post that on pirate and you might be cryin for mommy... looks like a pretty nice dline, as others mentioned flip it around.. and i always make it a point to at least put a drop of blue locktite on the drive line bolts, dont want them rattling loose.... dont forget to grease that puppy to.. new joints dont have much grease in em.
Old Jan 20, 2009 | 09:35 PM
toyabro's Avatar
thanks alot guys for the help,greatly appreciated !!! i have a good knowledge about mechanics but, i just got this toyota and learning more about it. the driveshaft was already like that when i bought it. it worked fine before i put the lift.
Old Jan 25, 2009 | 03:43 PM
dropzone's Avatar
Fossilized
so did flipping it around do anything?
