Pre 84 Trucks 1st gen pickups
Egr questions
Old Oct 19, 2021 | 09:16 PM
coleboy11's Avatar
Egr questions
My 77 20r is still bucking after a carb rebuild and i suspect the egr is bad. I have it removed and soaking in brake fluid. How can I tell if the valve is either stuck open or closed? Any details would be appreciated. These things are like 200 bucks new
Old Oct 20, 2021 | 04:59 AM
Melrose 4r's Avatar
5 Year Member
Just see if the pintle moves when vacuum is applied to the small port on top. Use your mouth, a vac pump, or another vehicle running. Also see if you can pass air through the larger port when closed. Again by mouth. Vac applied to the small port opens the large port. Lots of times they get coked up and you never notice. If it leaks because it’s stuck partially open, it’s very noticeable in the way it runs in my experience. But more likely to be stuck shut than open. Bucking could be a lean condition caused by a vac leak or other problem with the carb.
Old Oct 20, 2021 | 07:09 AM
coleboy11's Avatar
Well its full of carburetor cleaner and when I suck on the small vacuum port, nothing leaks out. Its been sitting overnight full of cleaner and still nothing. What does this indicate?
bambam69
Aug 19, 2016 09:15 AM
LSUfan71
Dec 22, 2010 07:25 PM
GoldenBeaR6
Dec 5, 2010 07:46 PM
Junkers88
Apr 25, 2008 06:32 AM
montanatoy
Apr 26, 2007 03:16 PM
