Pre 84 Trucks 1st gen pickups
ducatipaso's parts hauling gem
Old Apr 27, 2011 | 08:17 AM
  #141
83's Avatar
83
Chain of events...
At least you aren't getting discouraged. Yeah, you replace one part of the system with a stronger part, and the old weaker parts will start failing.
Good work! That's a fun project, you're replacing most fairly cheap and easy parts, and that truck just keeps getting better and better.
Old Apr 27, 2011 | 08:28 AM
  #142
ducatipaso's Avatar
yeah the truck was a delicate ecosystem of worn out parts held together with 32 years of grease and dirt... I expected these chains of events to occur.
fortunately, i have a FLAP that's 1 mile away and has this stuff in stock for good prices.
the only disheartening discovery so far is that the diff is shot. turning either axle by hand yields a tic tic tic tic tic - probably a broken tooth or worn spider gear. I'm assuming that just about any 4-cyl 2WD diff will swap in?
Old Apr 27, 2011 | 08:30 AM
  #143
ducatipaso's Avatar
my little hotwheel score makes me want to put JDM spec fender mounted mirrors and hilux badging.
Old Apr 27, 2011 | 08:43 AM
  #144
4toy89's Avatar
where exactly are you located in oregon? Im in Tigard and am always looking for new toyota people.
Old Apr 27, 2011 | 10:01 AM
  #145
ducatipaso's Avatar
I'm right by PCC sylvania. Very close to you.
Old Apr 27, 2011 | 10:43 AM
  #146
4toy89's Avatar
O nice im right next to bridgeport off of durham
Old Apr 27, 2011 | 11:01 AM
  #147
83's Avatar
83
Not sure what diffs will fit in your truck. I don't know the 2wd's as well. I'm guessing that any 2wd 22R/E will fit, though you'll either need to drill new bolt holes for the flange if you go with a later model, or buy something like this. Not sure if they work for 2wd.
Old Apr 27, 2011 | 12:44 PM
  #148
ducatipaso's Avatar
well, I'm gonna casually start looking at the local pick a part. at least yanking a diff is easy on a truck like this. heck, nothing's overly difficult on this thing.
Old Apr 27, 2011 | 01:02 PM
  #149
83's Avatar
83
Nope
I was really surprised and happy at how easy it was to swap my rear diff. The only aggravating part was drilling the new bolt holes in the flange...I went through a couple batteries on my hand drill. With a better stocked shop and a drill press I'm sure it would be cake. And I got the diff from someone on Marlin's site for the price of shipping.
Old Apr 27, 2011 | 02:25 PM
  #150
corax's Avatar
Originally Posted by ducatipaso
thankfully, toyota was smart to design the booster in a way that it won't fill up with fluid
I wouldn't bet on it, not completely anyway. My brake booster popped a couple years ago. When it got changed I drained almost a full quart of brake fluid out of it
Old Apr 27, 2011 | 03:47 PM
  #151
ducatipaso's Avatar
heh well I hope to not find out. not soon anyhow.
Old May 2, 2011 | 10:01 PM
  #152
ducatipaso's Avatar
when I have spare time, I do stuff. television sucks.
cant wait to put it back on.
Old May 2, 2011 | 10:02 PM
  #153
ducatipaso's Avatar
i should adjust the valves while i wait
Old May 2, 2011 | 10:38 PM
  #154
gte175x's Avatar
yessir. I plan to sympathetically restore it and use it as a pickup truck.
a little elbow grease and this old toyota vinyl cleans up smartly
Wow!!!! what'd you use?
Old May 2, 2011 | 10:54 PM
  #155
ducatipaso's Avatar
now I have an engine bay I can be proud of. I can't wait to get a header on this thing.
before:
after
Last edited by ducatipaso; May 2, 2011 at 10:57 PM. Reason: put the before pic in for reference
Old May 2, 2011 | 10:55 PM
  #156
ducatipaso's Avatar
meguiar's #39 followed by #40
Old May 3, 2011 | 06:16 AM
  #157
JustDSM's Avatar
Very, very nice work on that valve cover! I was planning to give mine the very same treatment!
Old May 3, 2011 | 07:08 AM
  #158
ducatipaso's Avatar
thanks. an evening of scrubbing, painting and baking does the trick.
Old May 3, 2011 | 07:19 AM
  #159
Outsane's Avatar
Hot damn that looks good
Old May 3, 2011 | 07:46 AM
  #160
xxxtreme22r's Avatar
what did you use to paint the valve cover. I like the texture on it. Best one I've seen by far.
