Pre 84 Trucks 1st gen pickups
Anyone know these 82 radio outs?
Old Dec 26, 2016 | 05:50 AM
1980 Pinellas's Avatar
White is keyed to the ignition and green is ground , those two get the light working on the radio and turn the radio on / off with the key
any chance anyone knows where to hook the other three?
Old Dec 26, 2016 | 11:13 PM
Co_94_PU's Avatar
Show the rest of it, you aren't getting a four channel speaker system working with three wires that is maybe a power antenna. The audio is probably on the din plug hiding slightly off frame. Wiring diagrams on these are either on the cover or under it usually..
Old Dec 27, 2016 | 04:08 AM
I was starting to wonder about that plug , I'm going to go digging around back there but I don't think I have it. Would really like to save the dash , I could never cut it
Old Dec 27, 2016 | 04:33 AM
Old Feb 26, 2017 | 11:04 AM
Ok well
Anyone know where or what this wire does? I'm guessing electric choke, which I have. I was doing to desmoging and when I got done noticed this loose
Old Feb 26, 2017 | 01:17 PM
dropzone's Avatar
Fossilized
You go from a radio to a carb??
the carb wire is electric choke like you said..
Old Feb 27, 2017 | 02:58 AM
Figured that
problem is there are so many plugs with nothing plugged, hopefully I can find a photo I took of the engine
