Pre 84 Trucks 1st gen pickups
Anyone know if these wheels fit without spacers?
Old Nov 15, 2022 | 08:24 AM
1980 Pinellas's Avatar
Thank you !
Old Nov 16, 2022 | 09:13 AM
Old83@pincher's Avatar
You will need spacers. Without they will hit the tie rod ends.
If I recall correctly "solid axle" back spacing is 3.5" and IFS back spacing is 4.25" which those wheels are.
Old Nov 19, 2022 | 03:08 AM
Thanks for the reply . I’m going to see what’s on there and see if I can at least run a smaller spacer
Old Nov 19, 2022 | 12:03 PM
After firing up the "grey matter" Intel processor I had a few more thoughts.
Maybe 16" rims or bigger would work with that back spacing (4.25") 15" definitely not. With a 15" the tie rod is less than little finger feeler gauge width from the bead area of the rim...just checked on mine. Also be mindful of the brake hose/line and bracket. Also clearance between the tire and the springs at full steering lock/stop.
lastname_firstname
Sep 24, 2012 11:19 AM
traxxi2003
35
Mar 18, 2011 07:57 PM
Nate08
15
Oct 17, 2007 06:11 PM
