Pre 84 Trucks 1st gen pickups
Aluminum radiator help, 82 yota 4x4 manual trans
Old Mar 10, 2018 | 07:31 PM
1982Redyota's Avatar
Exclamation Aluminum radiator help, 82 yota 4x4 manual trans
hi everyone, I have been looking online in hopes of trying to find an aluminum radiator for my 1982 toyota pickup 4x4 manual trans, I have used the stock radiator measurements to try and find a aluminum radiator close to the stock measurements with no luck, if anyone reading this can please help on my search any information will be greatly appreciated. thank you
Old Mar 10, 2018 | 08:29 PM
muddpigg's Avatar
I found one on EBay for my 4rnr. Was close though listed as direct fit. Took some elbow grease and a rat tail file to align mount holes. Then a good bit of shroud trimming. Aluminum 3 core for about half of others. On phone so pulling up eBay purchase history will have to wait.
Old Mar 11, 2018 | 04:16 AM
wyoming9's Avatar
Red face
Why ?
By Aluminum you mean completely Aluminum ??
No Plastic tanks !
Any of the Aluminum 3.4 radiators will be able to be made to work.
You just need to make sure the outlets are in the correct location .
Custom brackets are simple to fabricate
I use the same Copper Brass Radiator in my 86 2.4 92 3.4 and my 2000 tacoma 3.4
Old Mar 11, 2018 | 10:55 AM
I want to thank you all for your responses, and information that you have provided. I'm now shopping around for an 84 all aluminum. I have found a place here in California called champion radiators they have the 84 pickup radiator but it is only for an automatic trans. I will call them up and see if they have a manual trans all aluminum.https://www.championcooling.com/ prices are good and they seem to be of good quality
Old Mar 11, 2018 | 11:06 AM
muddpigg's Avatar
Glad you posted back, looked on ebay can't find the exact one I got but there is others.
The automatic radiator will work. Some even prefer them and run power steering lines through transmission ports on rad. I haven't ever done that and have seen post of ppl going back and forth on pros and cons of set up.
dcramos72
Mar 29, 2017 04:41 PM
sharrack
May 15, 2015 05:26 AM
jeremyt
3.4 Swaps
14
Mar 17, 2009 06:13 PM
dannyh
Dec 23, 2005 09:23 PM
windancer4x4
Nov 13, 2005 07:54 AM
