Pre 84 Trucks 1st gen pickups
83 4x4 Fuel Pump
Old Mar 21, 2023 | 01:31 PM
Friscomail's Avatar
83 4x4 Fuel Pump
Folks,
My 83 4x4 seems to be lacking fuel pressure. No telling how old the electronic fuel pump (no manual unfortunately) is but does anyone have a set-up that works? It looks like you need about 5 PSI flow rate. The AC Delco has 4.5 PSI but any suggestions much appreciated.
Old Mar 22, 2023 | 09:49 AM
Punjab's Avatar
So many questions...
We're talking about an '83 22R here or is this for a different engine?
What carburetor? Why is your 22R using an electric fuel pump? What is the part number/manufacturer of your current fuel pump?
What makes you think you have low fuel pressure? Do you have a regulator in-line? Does this setup run a return line to the tank?
Old Mar 22, 2023 | 12:48 PM
Friscomail's Avatar
It is a 22r (sorry)
Not sure brand it looks old
the previous owner screwed up manual pump threads badly
Thx for reply
Old Mar 22, 2023 | 06:11 PM
Punjab's Avatar
Low pressure flow rate depends on the carb spec. You can use a fuel pump rated for more than the carb can flow but you need to be able to regulate the pressure and send the extra back to the tank.
I believe the stock Aisin carb is around 5psi. Holley is around 5psi. Weber is 3psi.
There are many very cheap low pressure fuel pumps (or expensive ones) available online. I would get a decent low pressure regulator and a low pressure gauge so you're not guessing about what's going on anymore.
Old Mar 23, 2023 | 09:52 AM
Friscomail's Avatar
Thank you - that's the plan
83Project2
Feb 9, 2013 10:21 AM
tumble
Jan 21, 2011 02:22 PM
camaross
Oct 2, 2007 02:07 PM
