Pre 84 Trucks 1st gen pickups
83 22r idles sometimes
Old Jan 11, 2012 | 09:42 AM
littledigger's Avatar
i have a 83 engine and chassis with a 81 body and cab and swaped wiring harness .now the truck starts fine choke seems to work fine but after it warms up it wont idle. but it doesnt do it all the time it comes and goes so its hard to try to work on it . when its acting up the motor skips going down the road if the gas peddle is barely pushed, but push it to half trottle it stops. all vac lines are hooked up and seem to be right by haynes book. thanks for any help.
Old Jan 11, 2012 | 10:21 PM
crash121's Avatar
I would clean up the fuel system to start out. New fuel filter, make sure the pump is working correctly and clean your carb
Old Jan 13, 2012 | 11:32 AM
Not Far From Par's Avatar
Did you get this fixed yet..?
Are you running stock carb or otherwise?
Blamalam
Mar 12, 2022 07:34 AM
dumpster84
Apr 30, 2016 06:03 AM
87blyota
Aug 23, 2015 03:57 AM
Fakayayou
Aug 9, 2015 12:47 AM
kyletbert
Jul 17, 2015 11:39 AM
