82 Toyota OME lift before and after
also v6 calipers and fj rotors so she stops good now. Also new timing , water pump , oil pump etc so it fires right up and sounds good very happy about that. Found Teq marked glass from Japan 99% perfect 45.00 both sides! I’ll post up some pictures when those go in
Can I pick your brain, what parts did you use for the front brakes? I want to do the same upgrade but don't know where to look for the parts. Did they all bolt up to your truck or did you have to modify anything. What year did you get the V6 rotors and calipers from? I just want to be able to bolt everything up. I've heard that some mods are required for the backing plate unless you go with the eliminator kit, did you go that route also or did you mod the backing plate. Also, did you change out the master cylinder? I know a lot of questions but I'm new at this. All help would be appreciated
Thanks
