Pre 84 Trucks 1st gen pickups
81 clutch replacment
Old Dec 14, 2007 | 07:07 PM
notanymore's Avatar
so my friend has an 81 pickup 4x4 with a 21r in it and we are replacing the clutch and rad tomorrow and i want to know is there anything special to look out for while doing these? i have done a few clutches on second gen pickups so i have a pretty good idea on how to do it, but is there anything special i need to know?
Old Dec 14, 2007 | 07:20 PM
rowdy235's Avatar
With clutches prolly machine the flywheel. Check rear main seal while you in there, if you have any thought it MAY leak, replace it. You'll thank yourself later.
Radiator- Be sure to park the truck on a fairly steep hill with the front up and run it for 5-10 minutes after installing the new radiator to "burp" the system. I have done it both on level ground and uphill, and I find the uphill works much better. Kind of optional, but I'd recommend it.
Hope this helps!
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
