Pre 84 Trucks 1st gen pickups
80 toyota 4x4 trans question
Old Oct 6, 2010 | 06:19 PM
walters's Avatar
just bought a 80 toyota 4x4 pickup, runs good but the shifter has a lot of slop in it, i took it a part and the steel ball on bottom of the shifter is wore out, this is one that the shifter sits on the side of the transmission, can you buy the hole shifter and just bolt it on, if so where...
Old Oct 6, 2010 | 06:56 PM
myyota's Avatar
The shifter seat bushing has probably just worn a way, you can get new ones from Marlin Crawler.
Old Oct 6, 2010 | 07:03 PM
82blueyota's Avatar
i put the new marlin shifter seat bushing and ball cap on my shifter.killed some of the slop but i had it out last weekend doing a fluid change and noticed that the grooves where the dowel pins that keep it in place had been augerd out a little.
Old Oct 6, 2010 | 07:04 PM
aquaprice's Avatar
I had a similar problem on my 81. (pited/worn and would pop out of gear.)Tried the new seat and it would not stay on. I actually picked one up at my local stealership. They had it on the shelf. Worth a try.
Old Oct 6, 2010 | 08:35 PM
dropzone's Avatar
Fossilized
marlin does not list the shifter seat bushing kit for a L-43 side shifted, only 81+ 5 speeds
To the OP, you might try some of these guys:
Originally Posted by ocdropzone
Toyota Truck Dismantlers: body parts/axles etc
The Toy Man (newberg, OR) http://www.thetoyotaman.com/
MazToy (troutdale, OR)http://maztoy.com/
Davez Off Road: http://www.davezoffroadperformance.com/
Yotayard (colorado) http://www.yotayard.com/home.htm
Jim's Got Parts (Denver, CO) http://jimsgotparts.com/
California Mini Trucks (Cali) http://www.calminitruck.com/
NIX99 (washington state) http://nix99.com/
Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/
toy truckc (CA) http://www.toytruckscalifornia.com/
Toy Connection (CA) http://www.toyconnection4x4.com/home.html
All Toyota Truck and SUV (CA) http://www.alltoyotatrucksuvparts.com/
ToyoKings (FLA) http://www.toyokingsusedparts.com/
Yotatech Classifields :https://www.yotatech.com/forums/f91/
TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3
Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4
Parts Locators: http://www.autopartslocator.com/
http://www.seekautoparts.com/
Thread on http://www.toyotadiesel.com/forums/showthread.php?t=343 with Parts sources/ links in Cananda & Australia
Old Oct 7, 2010 | 09:00 AM
walters's Avatar
trans
i think i got it figured out, i took it apart and welded the wallard groves up and grinded it back down smooth and strait, took about 80percent of the slop out and is working well, the pins that run in the grooves could be replaced and would prob take the other 20 percent out but is working so well i think i will leave it alone thanks for the help
GreenLion
Jun 7, 2021 10:49 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
Corey
24
Jul 15, 2002 07:53 PM
Krash
10
Jul 13, 2002 09:21 PM
