80 toyota 4x4 trans question
just bought a 80 toyota 4x4 pickup, runs good but the shifter has a lot of slop in it, i took it a part and the steel ball on bottom of the shifter is wore out, this is one that the shifter sits on the side of the transmission, can you buy the hole shifter and just bolt it on, if so where...
The shifter seat bushing has probably just worn a way, you can get new ones from Marlin Crawler.
i put the new marlin shifter seat bushing and ball cap on my shifter.killed some of the slop but i had it out last weekend doing a fluid change and noticed that the grooves where the dowel pins that keep it in place had been augerd out a little.
I had a similar problem on my 81. (pited/worn and would pop out of gear.)Tried the new seat and it would not stay on. I actually picked one up at my local stealership. They had it on the shelf. Worth a try.
Originally Posted by myyota
(Post 51566918)
Originally Posted by 82blueyota
(Post 51566928)
To the OP, you might try some of these guys:
Originally Posted by ocdropzone
(Post 51081918)
Toyota Truck Dismantlers: body parts/axles etc The Toy Man (newberg, OR) http://www.thetoyotaman.com/ MazToy (troutdale, OR)http://maztoy.com/ Davez Off Road: http://www.davezoffroadperformance.com/ Yotayard (colorado) http://www.yotayard.com/home.htm Jim's Got Parts (Denver, CO) http://jimsgotparts.com/ California Mini Trucks (Cali) http://www.calminitruck.com/ NIX99 (washington state) http://nix99.com/ Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/ toy truckc (CA) http://www.toytruckscalifornia.com/ Toy Connection (CA) http://www.toyconnection4x4.com/home.html All Toyota Truck and SUV (CA) http://www.alltoyotatrucksuvparts.com/ ToyoKings (FLA) http://www.toyokingsusedparts.com/ Yotatech Classifields :https://www.yotatech.com/forums/f91/ TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3 Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4 Parts Locators: http://www.autopartslocator.com/ http://www.seekautoparts.com/ Thread on http://www.toyotadiesel.com/forums/showthread.php?t=343 with Parts sources/ links in Cananda & Australia |
trans
i think i got it figured out, i took it apart and welded the wallard groves up and grinded it back down smooth and strait, took about 80percent of the slop out and is working well, the pins that run in the grooves could be replaced and would prob take the other 20 percent out but is working so well i think i will leave it alone thanks for the help
