Pre 84 Trucks 1st gen pickups
33X10.5 R15 tires
Old May 9, 2015 | 08:59 PM
joesgarage's Avatar
33X10.5 R15 tires
Are 33X10.5 to much for 22r to run? Any modes to the tranny to play it safe? Thank you!
Old May 11, 2015 | 08:33 AM
kawazx636's Avatar
Assuming that the engine isn't worn out, it'll turn them, but it won't like it. You likely won't be able to hold or pull 5th gear. You'll want to re-gear your axles for pretty much any tires over 31"
Old May 11, 2015 | 09:43 AM
joesgarage's Avatar
Thank you
Thank you!
Old May 11, 2015 | 09:54 AM
fierohink's Avatar
Do you know if your truck has 4.10s or 4.30s or 4.56s? If it originally came with the small tire package the 265s and not the 31x10.50s you're in for a slow trip wherever you go.
The 4.10s were slow and under powered with 31x10.50s. You are now increasing the rotation by nearly 10%. Adding extra weight for the motor to rotate and a significantly bigger footprint if rolling resistance.
4.56s will be you and your motors friend. You won't break any parts driving around with 33s unless you try to crawl over something. Then leverage will not be kind.
Old May 11, 2015 | 11:11 AM
joesgarage's Avatar
I have a brand new jasper motor and a rebuilt transmission. I might just keep my BFG 265 tires on. Sounds like a lot of work for those tires. Thanks for the info guys.
Old May 13, 2015 | 06:36 AM
mwisham's Avatar
I have a 1980 4X4 with a 20R and the 33X12.50's were too much for it. I went down to 31X10.50's and it runs fine with them. It put my speedo off by 5 MPH but I can deal with that. My engine is not bone stock. I have de-smogged it, added a Weber 38/38 carb, header and DUI distributor with E-3 plugs and it is a 4 speed trans.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
