Pre 84 Trucks 1st gen pickups
2wd verses 4wd oil pan and pickup tube
Old Oct 9, 2014 | 05:18 PM
Lithgow's Avatar
Quick question for the pros....previous owner swapped a 2wd engine into my 4wd truck. I am in the process of swapping the oil pans so that it has the correct pan. Does the oil pickup tube also have to be swapped or is it the same for both applications?
Old Oct 9, 2014 | 09:14 PM
Terrys87's Avatar
You will need to swap pick up tubes. I dont think you could get the pan on with the wrong tube if I am correct. Tube and pan must be swapped when going from a 2 wheel to 4 wheel style motor.
Old Oct 10, 2014 | 04:54 AM
Lithgow's Avatar
Thanks for the info!
vasinvictor
Jan 20, 2016 12:39 PM
Alaskan91
Sep 21, 2015 04:39 AM
puddlepirate
Jun 30, 2015 05:08 PM
HaveBlue
Aug 13, 2002 02:16 PM
growinseed
Aug 9, 2002 05:00 PM
