Pre 84 Trucks 1st gen pickups
2nd gen dash/interior in 1st gen.
Old Aug 27, 2017 | 05:54 AM
dirtdobberoffroad's Avatar
after I got the dash plate on I wanted to get the steering column in so I could mount the dash cross bar when I got it that far together I had to put the rest on just to see what it would look like. to mount the dash bar I used a punch to make a hole and roll sheet metal in I then threaded it to accept the factory dash bolts, I would rather put rivnuts in it but I don't have any. the bracket on the passenger side will be welded into place but the driver side I really don't know what to do with it. 1 bolt touches sheet metal!
will weld this one into place.
Old Nov 16, 2019 | 07:08 PM
Slacker you was correct on the work needed....I give up its not worth the work.....as far as the dash it fits no problem but the HVAC is a pain and not worth dealing with....
