Pre 84 Trucks 1st gen pickups
20R Timing: what hoses to disconnect?
Old Apr 6, 2006 | 10:27 PM
MaddMaxx's Avatar
From: Under the Evergreens, in the beautiful NorthWest
Hi. 1980 Truck 20R Head/22R Block
I cant remember what hose(s) to disconnect while timing it.
I know its one of em on the distributor.
And also, I dont even know if they are connected right. The diagram on the hood is now just blank wrinkly sticker.
There is a one way valve that goes a certain way, i dont know which way?
The 2 pipes, upper, and lower which one connects to the distributor diaphram large and small?
Thanks.
Old Apr 7, 2006 | 07:32 AM
kyle_22r's Avatar
i would like to say that you just disconnect and plug both of the lines on the distributor. timing is 8*BTDC on a 20R.
Old Apr 8, 2006 | 09:08 PM
MaddMaxx's Avatar
And what part of the vacuum canister on the distributor requires suction?
Old Apr 8, 2006 | 10:43 PM
kyle_22r's Avatar
...plug the lines themselves, not the distributor ports. when vacuum is applied to the distributor ports, it advances the timing. you don't want this when setting the idle timing.
LotOMiles
Sep 14, 2015 11:45 PM
sanctfy
Sep 13, 2015 06:33 PM
noahstancik
Sep 10, 2015 10:47 AM
--Oz--
Sep 6, 2015 01:06 AM
128keaton
Sep 3, 2015 05:09 PM
