Pre 84 Trucks 1st gen pickups
20R/22R EGR Valve
Old Mar 7, 2013 | 12:12 PM
80banana's Avatar
20R/22R EGR Valve
Can an 81+ EGR valve from a 22R be used on a 80 20R? They look identical. Can't seem to get mine clean enough to hold a vacuum
Old Mar 7, 2013 | 01:11 PM
83's Avatar
83
I don't have a definitive answer except...one way to find out!
I had some luck soaking my valve in brake cleaner overnight...
Old Mar 7, 2013 | 01:32 PM
80banana's Avatar
Yep, I've filled it up with aerosol carb cleaner and am letting it soak some more. The reason I think that there's something wrong with mine is that when try to pull a vacuum at the egr's outlet (simulating engine vacuum at idle coming from the egr pipe), I can't get a solid reading...just hear a hiss and the gauge drops to zero...so I'm guessing air is leaking around the internal valve/seat or in from the top seal around the internal valve's stem.
Old Mar 7, 2013 | 01:46 PM
83's Avatar
83
And deleting it isn't an option? Emissions, etc?
Old Mar 7, 2013 | 01:54 PM
80banana's Avatar
Yep, got a smog check coming up
idadan208
Sep 7, 2015 09:06 AM
Scatterbrain
Sep 3, 2015 06:46 PM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
