Pre 84 Trucks 1st gen pickups
1982 4wd Power Steering leaking fitting - Banjo Fitting?
Old Apr 19, 2015 | 08:58 PM
Kamo_82's Avatar
I need to know if the banjo fitting is stock because its leaking can't even keep fluid in the reservoir, I have to figure this out by Friday the 24th thanks in advance.
Attached Thumbnails 1982 4wd Power Steering leaking fitting - Banjo Fitting?-image.jpg
Old Apr 20, 2015 | 01:10 AM
dropzone's Avatar
Fossilized
Like i said in the other thread, that doesn't seem stock to me.
it looks like there is a washer under that banjo fitting..
Old Apr 20, 2015 | 12:18 PM
Kamo_82's Avatar
Yeah there is 4 copper washers on it two on top two on bottom of the fitting. I can't find the stock line that goes there
Old Apr 22, 2015 | 05:57 AM
kawazx636's Avatar
Toyota did not use banjo bolts for the power steering and when you do use banjo bolts, you only need two copper washers - one on each side. The extra washers may be causing your problems, but then again the extra washers could have been a "fix" for a banjo bolt that was too long (not the correct way of fixing that problem though). Also, I would imagine that the banjo bolt would be much more restrictive than the stock pressure hose fitting thus creating a lot more pressure on one side of the fitting and restricting volume which I imagine would greatly restrict the function of the gear box.
You may be able to stop the leak by installing new copper washers. Any parts store should have them in the brake section and you can some thicker washers if necessary (if indeed the banjo bolt was too long). Make sure you thoroughly clean hose fitting, banjo bolt and around the inlet of the gear box so don't have any debris present that will prevent a good seal.
Ideally, I would get a new hose. They are available pretty much anywhere, but here is what you're looking for:
http://www.4wheelparts.com/Brakes-St...FVc6gQodIIMARA
Old Apr 22, 2015 | 10:23 PM
dropzone's Avatar
Fossilized
found this at o'riellys
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
