Pre 84 Trucks 1st gen pickups
1981 Hilux with 1993 pickup a/c unit?
Old Apr 4, 2018 | 01:40 PM
FrakKing's Avatar
I'm looking at buying a nice 1981 Hilux and I have a '93 pickup with working ac. Can I swap it over to the Hilux from the pickup?
Old Apr 4, 2018 | 04:29 PM
slacker's Avatar
major work !! heater boxes are completely different , everything is way different .. I would say NO !
Old Apr 4, 2018 | 08:16 PM
FrakKing's Avatar
Even if it has the 22r?
Old Apr 4, 2018 | 08:22 PM
old87yota's Avatar
Yes, it would still require major work with the 22R. The HVAC system changed for every generation truck. The 1979-1983 would be different than 1984-1988 which is different than 1989-1995.
The problems you would run into would be less on the engine side and more in the interior heater and air conditioning box under and behind the dashboard.
Old Apr 5, 2018 | 05:14 AM
toy_tek's Avatar
Certain Early Hilux ac parts are either hard to find or expensive. The ac was a dealer add-on (as I understand) and not integrated with the heater/fan as later gen truck units were. The evaporator core is not being made (I couldn’t find a new one anyway). The empty core box is something like $400 from Toyota but I’m not even sure it’s actually available.
Im in the process of adding ac to my 83, after searching for almost a year I finally found a donor truck from same era and pulled everything. Luckily most of those parts are still usable. I checked on using a system from a later gen truck, and although anything is possible, realized it would be very labor intensive with a lot of modification and probably not look very good.
Old Apr 5, 2018 | 10:00 PM
FrakKing's Avatar
Thank you for your replies. It sounds very unrealistic to have ac in that '81. I may just stick with my '93 for now.
Old Apr 6, 2018 | 07:43 AM
Lons81's Avatar
Buy a system from Vintage Air or Old air Products and have it installed or DIY..You can see what I did in my 81 Build thread
Old Apr 6, 2018 | 09:03 AM
old87yota's Avatar
^^ This is probably your best option if you really want A/C in your 1981.
Old Apr 19, 2018 | 01:52 PM
MVP's Avatar
MVP
Just bought a 1983 4WD yesterday to join my 4runner stable. AC is a must in Phoenix. Subscribed.
Old Apr 27, 2018 | 03:52 PM
MVP's Avatar
MVP
How's the AC project going? I'm in far SW valley - what part of Phoenix are you in?
Old Apr 27, 2018 | 09:24 PM
toy_tek's Avatar
well In reality it’s a 3rz swap and adding ac at the same time. I’m about half way through but most of the ac is just bolt-in from here. I’m central Phx off the 51.
Old Apr 30, 2018 | 05:42 AM
MVP's Avatar
MVP
Going more horses and AC at the same time. Wish I had the room and other projects completed so I could tear into mine like that. Would like to see the progression of the AC installation when you get there.
Thanks for your reply, trying to make connections with 79-83 owners in the PHX area. Long time 4runner guy with a renewed interest in these older beauties.
nomadzoul
Oct 17, 2014 11:08 AM
nomadzoul
Jul 17, 2014 05:18 AM
HighLux
13
Mar 21, 2011 09:31 PM
shsportsfan12
10
Jul 13, 2010 07:17 PM
81Hilux
49
Sep 16, 2009 01:05 PM
