Pre 84 Trucks 1st gen pickups
1980 Pickup: High Beams do not come on.
Old Nov 21, 2010 | 07:49 PM
ohp676's Avatar
When I turn on my high beams both headlights cut out. However, when I pull the handle back the high beams will come on. I checked power to the lights and when I do turn the high beams on, all prongs on the three prong plug have power to them, but the light doen not come on.
Please help. I'm stumped.
Old Nov 21, 2010 | 09:19 PM
truckman1966's Avatar
you should have a ground to each light. both filaments share a ground connection but have 2 power circuits. check your grounds, then check out your headlight switch
Old Nov 22, 2010 | 12:20 PM
ohp676's Avatar
Thanks for the reply. I figured it out this morning. I tore down the steering column all the way to the guts of the light switch. I took a thin sheet of sand paper and cleaned each connection of the brass/copper mechanism. After that the lights worked just fine. I was also able to straighten my steering wheel at the same time.
Old Nov 22, 2010 | 06:09 PM
awesome!
80Truck
Oct 12, 2025 07:25 PM
Tacoma1313
Aug 17, 2015 05:44 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
luckypig44
Jul 19, 2015 11:25 AM
Poncho0206
Jul 10, 2015 06:21 PM
