Pre 84 Trucks 1st gen pickups
1980 20r fuel pressure question
Old Mar 11, 2009 | 01:44 PM
srhvipor's Avatar
I have a 1980 20r, with an electric fuel pump, there isnt even a place on the block for a mechanical one. It appears to be a universal fuel pump and is located under the hood fastened to the frame. It may be factory...not sure. Any way, it has a regulator between it and the carb. but has no gauge just numbers like a clock and there isnt much way to adjust it, it constantly needs a different setting. I have been thinking about getting a new regulator with a gauge. Does anyone know what the factory fuel pressure should be to the carb. on a 20r???
Old Mar 11, 2009 | 04:36 PM
slacker's Avatar
the trucks had a mechanical pump on the head .. if not , I would say the head somewhere along the line was replaced with a car head . little trivia .
fuel pressure is a min 4lbs - 9lbs .. so pretty much any electric pump will work .
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
DrZero
18
Jul 24, 2015 11:31 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
88yodabasket
Jul 13, 2015 01:32 PM
