Pre 84 Trucks 1st gen pickups
1972 to 1978 Pickup ALTERNATOR CONNECTOR REPAIR PARTS
Old Jul 4, 2016 | 12:24 PM
13Swords's Avatar
5 Year Member
After having recently found some of the wires to my alternator broken off at the very back of the plug, I've been looking for replacement or repair parts, & have found a few. Will fit 1972 to 1978 Pickups; may fit some pickups from 1979-1984. Here they are:
http://www.globalsoftware-inc.com/co...Connectors.htm
Part # 3P786.3. This is the tricky way to do it. You crimp on new female spade lugs to your wires, then push them thru the back of the new plug; they click in place in the plug. MAKE SURE YOU PUT THE RIGHT COLORED WIRE IN THE RIGHT PLACES ON THE PLUG OR IT'S DISASTER TIME!
http://www.repairconnector.com/produ...or-3-Wire.html
Pigtail type; just splice it into your existing wires. Solder splicing recommended, but you could use butt crimp connectors.
Blue & Green wire positions on plug are correct; Red wire matches up with White wire.
http://store.alternatorparts.com/c16...connector.aspx
More expensive but a little less hassle; butt connectors already on the wires. this item appears to be USA made by a company called JIMCO.
If you have the later plug type, where the single port is offset to one side, the last two places have those as well.
punks_is_4x4
Feb 23, 2016 11:52 AM
ClassicMike
Jan 26, 2016 11:10 PM
jacket990
Aug 31, 2003 10:11 PM
Paul S
Jun 20, 2002 05:07 PM
