FS[MidAtl]: 86-95 Beefy IFS steering parts
Old Mar 20, 2018 | 08:49 PM
RatLabGuy's Avatar
I have several parts for upgrading your '86-95 IFS to super beefy. These are intended for stock width (e.g. not LT) applications.
I have essentially everything for a complete replacement and mostly another. This is all custom stuff so hard to know price.
These are for running heims on the relay rod end, a beefy tie rod, and either a heim or FJ80 rods on the outer (see below).
There is:
- relay rod w/ holes reamed for 5/8 bolts - $100
- relay rod w/ holes reamed for 5/8 bolts AND brace bar welded on - $150
- set of tie rods, 1.5" 0.250 DOM, 1 end is 5/8 heim (included) other is FJ80 (included). So they bolt to the stock knuckle joint. The ends are a little rusty - this is ONLY from sitting for a few years. They were literally used on 1 race where the truck made it 1 lap (lol), they probably have 5 miles use total. They just *barely* clear the front frame mount. $100
- set of tie rods, mix of 1" and 1.25" w/ inserts welded. Have 5/8 heim on one end. other (outer) end is threaded w/ 5/8 hole for R-hand heim. This is to use heims on knuckle end for extra angle clearance. $100
- idler arm that has super-beefy bracing. No way it will bend. Sorry I do not know which shaft it has, or if it has the brass bushing (I got it from somebody else) $75
- used set of upgraded torsion bars. I believe they are 25 or 26mm. teeth is good shape. $75. Great for getting a little lift via cranking.
Will ship at buyers expense. I live in NE Maryland. Also I'll be going down through middle and eastern NC for Easter and can bring with if that helps.
Attached Thumbnails 86-95 Beefy IFS steering parts-20180320_233449.jpg   86-95 Beefy IFS steering parts-20180320_233506.jpg   86-95 Beefy IFS steering parts-20180320_233520.jpg   86-95 Beefy IFS steering parts-20180320_233600.jpg
Old Jul 3, 2018 | 06:49 PM
RatLabGuy's Avatar
Bumpity boo.
I now also have a set of upgraded (26mm?) Torsion bars. That with this stuff makes literally *everything* you need for a complete upgrade to your truck's front end.
Old Jul 5, 2018 | 07:55 AM
z05832's Avatar
I am interested in the torsion bars. Can you get a picture of them? Shipping to 85304?
Old Sep 22, 2018 | 11:21 AM
end_wrench's Avatar
Sent PM for tie rods.
Old Sep 27, 2018 | 10:19 AM
Ruined Adventures's Avatar
Idler Arm w/brace
PM sent
kfergiez
Mar 26, 2009 06:46 AM
sand73
Aug 27, 2008 07:33 AM
KSTacoma
Apr 6, 2008 04:39 PM
chimmike
Feb 17, 2007 05:01 PM
jacksonpt
Jul 15, 2002 07:41 AM
