MASS CLEAN UP ToYoTa PaRts Galore michigan
Old Apr 14, 2013 | 09:40 AM
tgmaul88's Avatar
Located in michigan
Most all prices are Shipped.
I do paypal unless your special.
More stuff added at bottom of page
IF you do not see something you need just ask me I might have it
89 Dual booster Diaphragm 40 Plus shipping
89 master cylinder 30 shipped OR BOTH for 75 shipped
Also a single diaphragm from a 86 4runner with MC 40 - 50 shipped
4 CYL gear housing minus carrier 60 shipped
Birfields 100 shipped
89 under dash plastic 30 shipped
89 clutch switch 15 shipped
2wd trans 120 shipped or will tear apart for part out
86 4runner clutch and brake bracket NOT BROKEN 50 shipped
Old Apr 14, 2013 | 09:41 AM
tgmaul88's Avatar
86 4runner air tube 40 shipped
4runner or truck mirror no light 25 shipped
86 IFS drive shaft NEED TO BE GROUND will cut up and ship in flat rate box for 50 shipped
86 non tach instrument cluster Works great 50 shipped
I have 4 sets of front calipers
make offer
89 engine wire harness single cab 75 shipped
89 arm rest 15 shipped
IFS calipers need cleaned 30 shipped
89 single cab 22re ecu 80 shipped
89 power steering Res 25 shipped
tgmaul88's Avatar
89 single cab wiper fluid RES 30 shipped
Old Apr 14, 2013 | 09:42 AM
tgmaul88's Avatar
89 single cab engine coolant res 30 shipped
89 multi switch works perfect 45 shipped
set of IFS wheel hubs 50 shipped for two
89 throttle body 22re efi
89 injector rail with only TWO injectors and cold start injector 50 shipped
KX 89 4x4 single cab 22re ignitor and coil 70 shipped
Old Apr 14, 2013 | 09:44 AM
tgmaul88's Avatar
lower 89 intake manifold 50 shipped needs small repair
Size:  57.2 KBName:  IMG_4376_zpsd3220298.jpg
Cleaned 89 upper efi manifold ready for paint 75 shipped
89 steering shaft
Old Apr 14, 2013 | 09:45 AM
tgmaul88's Avatar
prices are obo unless you see it is a fair price listed
Old Apr 14, 2013 | 03:15 PM
aye87's Avatar
i need a fender seal/splash shield on passenger side inner (2 piece) not the plastic one but the one close to the engine, if it is in good shape let me know
my zip code 19038
Old Apr 14, 2013 | 07:52 PM
tgmaul88's Avatar
triple drilled flange and IFS wheel hubs SOLD
Old Apr 16, 2013 | 06:40 AM
Nervo19's Avatar
I want those 4Runner plastics if purchaser flakes! Do you do PayPal?
My compliments on a very thorough part out and great pictures.
Old Apr 18, 2013 | 07:22 AM
tgmaul88's Avatar
sorry they already in the mail sold
Old Apr 26, 2013 | 07:48 AM
tgmaul88's Avatar
More stuff to add for sale:
w56 shifter 40 shipped OBO
84-88 and 89 in 4runners Side kick panel 25 shipped
89 single cab dash trim 35 - 45 shipped depends on how far away you are
4runner tail lights and I do have both from blinkers 50 shipped
s12w brake calipers 45 shipped
old rockers 20 shipped ?????
slightly used osk timing kit with all the stuff 30 shipped
89 dash. not perfect but better than nothing PM for pricing
Size:  65.9 KBName:  IMAG1188.jpg
89 22re in dash wiring harness 75 shipped
steering wheel cover that says toyota 25 shipped
Old May 2, 2013 | 04:53 PM
tgmaul88's Avatar
top bump to the top
Old May 11, 2013 | 06:59 PM
punchy11's Avatar
Pm/email sent on climate display and 89 shift boot
Old May 13, 2013 | 05:30 AM
tgmaul88's Avatar
bump for edit
Old May 19, 2013 | 07:35 PM
1st time 4runner's Avatar
do you have the tube work from the mass air sensor to the intake of the efi body for a 89 4runner 4cyl 22re.Im in socal.Thanks
Old May 30, 2013 | 03:05 PM
tgmaul88's Avatar
Edited post
Old Nov 6, 2013 | 02:04 AM
Hooperdog's Avatar
PM/email sent.
Old Nov 8, 2013 | 08:44 AM
tundup93's Avatar
What spline birfields are they?
Old Nov 10, 2013 | 04:55 AM
Hooperdog's Avatar
I still need the parts
Old Nov 10, 2013 | 06:31 PM
butchwood's Avatar
how much for the throttle body shipped to 29851
