FS[MidWest]: [Colorado] 7MGTE Powered Built 93 Pickup
Old May 22, 2017 | 12:49 PM
kalmah's Avatar
I am putting feelers out for my built 1993 Toyota Pickup. This thing can handle almost any trail in Colorado and get you to and from the trail head in record time! Great for camping too! Can't really justify owning it when I only take it out 1-2 times a year on the trails.
$8000 OBO
Engine
-7MGTE out of a 1987 Toyota Supra Turbo
-Honed & Polished Cyclinders, Crank, Rods, Complete Valve Job, Decked Block
-Titan Motorsports MLS Head Gasket
-ARP Head Studs
-Crank Scraper
-Rear Mounted Griffin Radiator and Resevoir
-Dual SPAL High Performance Radiator Fans
-400HP Capable FMIC
-New 140 AMP alternator (Drift Motion)
-New Idle Speed Control Valve
-Optima Red Top
-Trail Gear Battery Mount
-Toyota CT26 Turbo w/ 57 Trim
-AEM Short Ram Intake
-Upgraded Oil and Coolant Turbo Lines
-Custom 3" Turboback Exhaust
Drive Train
-Toyota R150F 1998.5
-Trail Gear Trail Creeper 2.28 x 4.70 Dual Trasfer Cases w/ 23 Spline input and coupler, 30 Spline Output
-Ford Daytona 9" w/ 5.13 Yukon Gears, Ford Mini-Spool
-Dana 44 w/ 5.13 Yukon Gears, Welded, Flat Top Knuckles
-Custom Square Front Drive Shaft
-Custom Rear Driveshaft (recently balanced at Drive Line Services)
-Warn Locking Front Hubs
Suspension/Steering
-SAS'd
-IFS Steering Box
-OME Springs, Antiwrap leafs on rear
-Custom bump stops
-Bilstien Shocks
Wheels & Tires
-Allied 17" 5x5.5 Beadlock Wheels
-Goodyear MTR w/ Kevlar 33"x12.50" w/ Full Spare Spare (About 50% wear left)
Exterior
-New Front Windshield
-Sprayed Flat Black
-Removable Bed Rack
-40" LED Light Bar
-LED Rock Lights
-LED Reverse Light
-Custom Tubed Bed / Semi Caged
-Trail Gear Front Bumper
-Bud Built Crossmember
-Custom Rock Sliders
-SmittyBilt 9000Lb Winch w/ Synthetic Rope
Interior
-V6 Gauge Cluster w/ Green LED Lights
-Prosport Boost and Coolant Gauges (Green)
-Toyota Celica Seats
-Sony Xplod Speakers
-Kenwood Nav Unit, Bluetooth/DVD
-Radioshack CB Radio
-LED Lighting
Comes with:
-Hi-Lift
-Dana 44 Armored Diff Cover
-Fire Extinguisher
-Extra Transfer Case(s)
-Extra Engine Stuff, Hoses, Clamps, Electronics, Lexus MAF
The Bad
-Leaks a bit of oil, fairly certain its from CPS seal, not enough to be concerned about
-Needs new rear axle seals, re-tap on the 3rd member breather nipple
-Power steering is currently the weakest link, needs a Hydro setup or cooler setup at a minimum
-Getting air bubbles out of the coolant lines has been kind of a nightmare, runs nice and cool otherwise
-No Parking Brake
-Speedo/Tach doesn't work
-Dont have a working key for door locks
Old May 30, 2017 | 12:01 PM
kalmah's Avatar
Price drop!
