FS[MidAtl]: 93 pickup sas exo western pa
Old May 5, 2019 | 06:02 AM
kenbo53's Avatar
Does great off road good frame 4cyl 5 speed, inspected, 35in mtz with full size spare ¼ tread. Toyota axles with 5.29 gears front and rear grizzly locker in rear. Front has trail gear 30 spline chromoly axles and hub gears high steer and trunnion bearing eliminators, fabricated axle housing with 5/16 dom axle tubes. Shocks and leaf springs all new within the last couple years, traction bars front and rear. Fabricated 5ft bed with 20 gallon fuel tank. Exo cage, sliders, tube fenders, bumpers nicely tied in and stout, a set of tube doors and smittybilt 9500lb winch. Body is in good shape rust wise lots of dents mostly in the front fenders and pasenger door, both doors close ok and don’t leak. Glass is good other than a crack in the very corner of the windshield doesn’t affect visibility. Drives ok for what it is motor is carbureted and doesn’t idle well and has a few small coolant and oil leaks, it was kind of a temporary setup so I haven’t messed with it much. There’s a few other minor issues here and there but I have driven and wheeled it as is with out any problems. I also have a t100 parts truck I was going to swap the v6 from that can go with it it did run but doesn’t currently. Just don't have time for the hobby anymore $3000
plus a pile of other parts.
petyamiller
May 20, 2010 05:53 PM
TachedOutOffRoad
Sep 24, 2007 05:46 AM
ryanflknr
Aug 7, 2007 08:53 AM
yotaman
Jul 10, 2006 06:09 PM
MellamoPOUND
Oct 11, 2005 05:39 AM
