In Northern Ca. Oroville about 1.25 hrs above Sacramento.
Holy Grail 2nd Generation Toyota 4runner, 22re, 5 speed
I just bought a first Gen 4wd pickup that I could not pass up on and can't keep both even though I wish I could So this goes up for sale
.. I drove this 4runner to the Marlin Crawler round up at the Rubicon last weekend and it performed flawlessly, then drove it home. Very capable for the trail just the way it sits as well as wonderful road manners.
I love this 4runner and have put a lot of time and money into it. It drives Fantastically, Is currently smogged and ready to drive anywhere. I built using the best of everything. CLEAN TITLE IN MY NAME Body is very clean with ZERO rust Tracks perfectly straight down the road with no vibrations or pulls. Absolutely wonderful driving 4runner!! I sought out this exact 4runner to build. This has manual windows and locks so none of that stuff to go out.
It has 238,000 miles on the odometer but you would think it had 38,000 miles. plus everything has been rebuilt to better than new
1995 SR5 4runner 22re 5 speed
AC
22re, Has been rebuilt at some point but I don't have paperwork. There are Heat tag rebuild tags on motor from the rebuilder for warranty, Runs fantastic, no leaks, no sloppy timing chain. Drive to the east case tomorrow if you choose
R151f Transmission out of the Toyota turbo 4x4 truck, Super tough transmission and 4.3 to 1 first gear. Much beefier transmission then any other Toyota manual. These alone in sell for $1000. No whines, no slop
NEW 23 spline Marlin crawler 4.7 transfer case gear. This is brand new gear set. Has 500 miles on it. Tranfercase gone through at time of gear set. These are the TOTAL spline marlin crawler gears. NO better gears out there..
Front range Off road Twin stick transfer case shifter. This allows 2wd Low Range. Nice feature especially when you have a front locker like the 4runner. Check out their websight https://frontrangeoffroadfab.com/
5.29 Gears
Rear ELOCKER, ZUK built differential. This guy is the best at Toyota diffs bar none. New NITRO 5.29 v-6 gears, with the larger 29 spline pinion, NEW KOYO bearings, Solid spacer, Triple drilled Flange. check out his websight... www.gearinstalls.com
Low range off road Elocker motor guard
New www.12voltguy.com elocker wiring Harness and switch. Wired in to key switch power. Switch is also wired to light up when the interior lights are on. Extremely professional harness and switch. Built in Vent for elocker motor. check out his websight www.12voltguy.com
Front 5.29 IFS diff with spartan locker 500 miles since installed. Was originally a ADD diff but I converted to Locking hubs.
NEW Aisin Hubs. Not the junk warns or mile markers, 100% new aisin fht-018 hubs. the best again
BFG KM3's 33x10.50x15's with Americas tire Lifetime tire certs. Rip a side wall get a new tire . Less than 500 miles Just paid over $1100 with warranty for these tires at Americas tire. These are the new KM3 BFG's that have only been out a couple months.
High Clearance HD Rock sliders
High Clearance rear rock bumper (comes with original chrome bumper if you want as well)
New CV's
New KYB shocks
New Rear coil springs
New Brakes
New rotors
New drums
new steering ends
New balljoints
New Cap and rotor
New Plug wires
New PCV valve
New Plugs
New air filter
New belts
Clean interior
Kenwood Bluetooth Stereo, New last month. Stream your phones music, Take calls over stereo etc...
Comes with new un-cracked Dash pad since this one has a couple cracks. Interior is really nice and everything works as it should
Come check this 4runner out. You will love it. Great platform the way it is or take it even further. My plan was to put a Diamond Front axle housing with a HP 5.29 third. Would be the ultimate SAS if you wanted to go that route. Also my plan was to do a 3RZ motor swap as well. But I think I am going to do all of this to the 1st gen
Do not email me asking for my price. It is clearly posted. Please Don't waste your time or mine. If you are serious come look..
