FS[SouthEast]: 1994 Toyota Extracab DLX Pickup, 2wd 5spd, 22RE,
Old Feb 26, 2023 | 07:03 PM
twotwore's Avatar
Want to sell: 1994 Toyota Pickup DLX Extracab, 2 WD, 5 spd MT. $3,100, REDUCED $2,500, Lake Worth, FL. Make me an offer!
22RE, A/C, PS, PB, 169,000 miles, original owner, runs and drives. Regular oil changes, coolant flushes, MT and differential gear oil changes, brake fluid/clutch fluid/power steering fluid changes. Does not burn oil. Slow oil leak from top front. Timing chain kit with metal backed guides at about 115,000 miles. Clutch has about 50,000 miles but mostly highway. A South Florida car entire life. Interior in good condition. Small tear on left side of driver seat. Has body rust behind the front fenders. Newer GT Radial Touring Plus tires (OEM size 205/75/R14). Newer spare tire. Front brake calipers/front brake pads/upper control arm bushings/all brake hoses/clutch slave cylinder, O2 Sensor, muffler all replaced in last 5,000 miles. A/C Compressor and drier replaced about 10,000 miles ago. 1994 first year OEM R134 A/C. AC works, even the idle up works! All lights and blinkers work.
Pioneer AM/FM/CD with detachable face and remote. Pioneer front 4” speakers in the premium Toyota behind dash speaker boxes. Also have pair of OEM rear side compartment Toyota speaker boxes form an SR-5 with speakers (not installed). Bedliner and Fiberglass ARE MX Series truck cap (needs new side window rubber seals and paint). They don't make this cap for this truck anymore. Newer steering damper, and center drag link (Moog). Never in a crash but was backed into while parked so some damage at front left side of the bed in front of rear wheel. Runs and drives but needs body work for rust and paint.. Buy to drive or part out yourself. Does not matter to me. Many interior parts interchangeable with 4X4 pickup and 4 Runner. Also have extra set of flow matched Fuel Injectors and a Valve cover gasket set. Probably due for valve adjustment. Can send more picks if you PM me.
Old Mar 21, 2023 | 04:48 PM
Hawkeye73's Avatar
Any pictures of the rust? Thanks
Old Apr 1, 2023 | 02:10 PM
twotwore's Avatar
I found some pics finally od the rust behind fenders. Can I send via PM? Not sure how to do that.
adamhairfield
Jun 17, 2016 11:57 AM
chrishf12
101
Nov 26, 2011 12:24 PM
89deluxe
Jan 12, 2008 11:56 AM
amgraham
Oct 7, 2007 01:35 PM
jwhite
Jul 16, 2006 07:21 PM
