1980 ToyotaTruck SR5 4x4 74,121 miles Coatesville, Pa
1980 Toyota truck inspected until October of 2013. This truck runs and drives well. The front axle service has been performed and it has a new weber carburator and new monroe shocks. Mechanically the truck does doesn't need anything and I would not hesitate driving this truck anywhere. It has 74,121 miles and I am still driving it so will increase slightly. The truck is a long bed (7.5') and the bed was rino lined. The truck also has a tow hitch however I have never used it to tow a trailer. The engine is the 22r and it is mated to a 5speed transmission. The wheels that are on truck will be replaced with the correct chrome SR5 wheels shown in the ad. The SR5 packages includes a tacometer and water temp, oil pressure and voltage gauges. $6250
Yea... unless there's significant documented service history, then there is no definitive way to say any 5 digit vehicle has any particular amount of miles.
According to the title from the PO the truck had about 6xxxx miles (I don't remember the exact mileage). He said his uncle owned it for about ten years before him. If someone lied on the odometer disclosure then it could have more than the mileage currently on the odometer. I've owned a bunch of Toyotas and this one is very clean when compared to most. I've had them with as low as 50k and as high as 400k and you can usually tell the ones with the higher mileage. The bottom line is I can I say what I know and that is the mileage it had on the odo and on the title. I have no way to certify the mileage.
QUOTE=MachtSchnell;52068356]Yea... unless there's significant documented service history, then there is no definitive way to say any 5 digit vehicle has any particular amount of miles.[/QUOTE]
