Engines - Transmissions Place above type items here
FS[SouthCent]: For Sale Eng Bldr street rv head and OEM valvetrain
Old Dec 9, 2014 | 08:31 PM
RyanV's Avatar
For Sale Eng Bldr street rv head and engine rebuild part firesale
Austin, Texas
512 924-5957
Ryan
I've updated the parts post down below and highlighted in green the parts that I think are a really good buy over what you'd pay anywhere else, right now.
I'm doing a 2RZ swap so I'm selling off all my 22RE engine build related items.
First up: SOLD
I've got a brand new Eng Bldr 22re high performance cylinder head and brand new OEM valvetrain.
The cylinder head is the Topline casting, 268 duration RV cam with Oversize stainless steel valves.
These parts below complete the cylinder head valvetrain, and are all new Toyota OEM parts still in the packaging. The OEM rocker arms aren't cheap, but they are superior to any aftermarket rocker arms available.
rocker arm x8 #13801-35010 $240
rocker spring x8 90501-14064 $8
rocker adjuster x8 90913-05019 $32
rocker nut x8 #90179-08049 $8
rocker shaft #13911-35010 $68
rocker shaft #13912-35010 $68
rocker shaft bushings #90560-16008 $10
rocker shaft screw x3 93210-56008 $3
cam thrust plate 13571-35010 $1.76
cam bolt 90910-02042 $4.20
distributor gear 13515-37900 $45.59
I've got over $1038 in this head and all related parts above. I'll sell everything above for $725+shipping
SOLD!
I'll be putting up pics shortly.
Old Dec 10, 2014 | 04:07 PM
madfie's Avatar
interested
I am interested. Pm sent.
Old Dec 10, 2014 | 09:20 PM
RyanV's Avatar
Next Up: I got a ton of mostly new OEM parts that I collected to rebuild my 22re.
All prices plus shipping, prices are low, but talk to me.
You won't find this OEM stuff any cheaper guaranteed.
New Bosch alternator, installed for like 30 miles - 75
Cleaned intake manifold w/fuel rail/injectors/TB SOLD
Flamethrower injector set with pigtail adapter 90
New OEM intake manifold studs and bolts 13 SOLD
New OEM oil pickup tube(make sure yours is clean if its used) SOLD
Exhaust manifold with 02 sensor 50 SOLD
New Goodyear gatorback radiator hoses all 3 hoses SOLD
New Gates belts 10 SOLD
New OEM Exhaust manifold studs and nuts SOLD
New OEM water pump hardware SOLD
New OEM C shaped water bypass hose under intake SOLD
New OEM pcv valve & grommett 10 sold
New OEM PCV formed hoses 12261-35011 , 12262-35060 SOLD
New Denso sparkplug wireset 18 sold
New OEM spark plugs 22re $8 sold
New OEM distributor cap and rotor 20 sold
New OEM distributor bolt(special bolt with thread sealant on it and large washer) SOLD
New OEM engine mounts $150 (these mounts cost $180 new. This is the best price youll see on OEM Japan mounts, everything else people sell is china) sold
New OEM W56 clutch release arm SOLD
New OEM throwout bearing 25 sold
New OEM pilot bearing 4 sold
Almost new OEM clutch set- Aisin PP, Luk disc with maybe 200 miles $80 sold
New OEM pressure plate bolts 5 sold
New OEM flywheel bolts 15 sold
New OEM full engine upper lower gasket kit - ALL gaskets and orings and seals for the 22RE $130
New OEM front cover bolt set 20 sold
New OEM thermostat SOLD
New OEM crank woodruff keys x2 $2SOLD
New OEM oil dipstick(so it fits tight) 13 SOLD
New Dorman harmonic balancer SOLD
5 Qts of Break in-30 Joe Gibbs 50 Best oil for a new motor, period.
New 22RE Decal for valvecover SOLD
New Denso oil filters x 2 for break in 6SOLD
Eng Bldr Front end set(water pump,oil pump, front cover,HD timing set) 100 SOLD
New Aisin Toyota oil pump SOLD
Cold Start injector round connector type that has been cleaned flowed at Witch Hunter $40
Old Dec 11, 2014 | 07:20 AM
RyanV's Avatar
I can get pics of anything needed, just lemme know.
Old Dec 11, 2014 | 07:23 AM
RyanV's Avatar
Old Dec 25, 2014 | 05:53 PM
SMC1010720's Avatar
Whats left for the 22re?
Old Dec 25, 2014 | 07:30 PM
RyanV's Avatar
5 Qts of Break in-30 Joe Gibbs 50 Best oil for a new motor 40
Cold Start injector round connector type that has been cleaned flowed at Witch Hunter $35
93' Intake manifold with all sensors. - 100
New 'non abs' high pressure power steering line 30
Sleaker
Aug 26, 2020 06:03 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
94whiterunner
9
Sep 22, 2015 07:28 PM
terminator
Jul 27, 2015 07:13 PM
horunner1x
Jul 10, 2015 06:33 AM
