Engines - Transmissions Place above type items here
FS[MidAtl]: 5VZ-FE Part out - Prices Listed with parts - Chesapeake, VA
Old Jan 25, 2015 | 06:24 PM
robb1887's Avatar
Story goes I went to go get this motor for a complete rebuild/blueprint/SCprep and caught that it had a window in the block for extra ventilation...
The guy really wanted it gone so I got it to part out and hopefully fund the next one.
Unknown milage.
Automatic
5VZ-FE
From the looks of it, the truck spun a bearing after piston removals, unsure of the overheating issues.
What is listed below is all I have. If it is not listed, I do not have it.
Prices are OBO, and do NOT include shipping.
Parts:
Torque converter (20 Splines) $75
Driver head (Bent valves) $100
Driver Cams $100
robb1887's Avatar
Engine Oil Dipstick $5
Flywheel/Flexplate SOLD
Misc engine hoses (cooling/vacuum) $20
Pass head $150
Old Jan 25, 2015 | 06:25 PM
robb1887's Avatar
Pass Cam $100
Lower intake runners $25
Upper intake runners $25
Timing belt idler pulley and bracket $15 (no play, no resistance)
Crank position sensor $15
Cam position sensor with bracket $20
robb1887's Avatar
Oil cooler $30
Toyota Coil packs and Aftermarket spark wires $60
Exhaust manifolds and cross over pipe $75
Mechanical fan bearing/bracket $20
Accessory pulleys $10
Water pump & lower rad pipe $30
Alternator with brackets $100
Complete uncut engine/trans wiring harness $100
Power Steering pump/res, pulley, and brackets $SOLD
robb1887's Avatar
Motor mounts $50
Upper Timing Belt Inner Cover $10 (Outer cover is SOLD)
AC compressor $100
Throttle body $SOLD
Fuel injectors/rail/hose/spacers $100
Old Jan 25, 2015 | 06:26 PM
robb1887's Avatar
Intake manifold $50
Driver valve cover $30
Pass valve cover $SOLD
Mechanical fan and clutch $50
robb1887's Avatar
Oil pump & pick up $45
Pending pictures
Old Feb 18, 2015 | 12:57 PM
Kayjodun's Avatar
Interested in valve cover
Im Interested in the driver side valve cover. I'm in Michigan.
Old Feb 18, 2015 | 12:59 PM
robb1887's Avatar
PM me your zip code and I will get you a shipping quote.
Old Mar 2, 2015 | 12:53 PM
nadakai's Avatar
Looking for inner timing belt cover, oil cooler, water pump and the misc hoses shipped to 67204
Old Mar 3, 2015 | 09:49 AM
robb1887's Avatar
PMed ya
Old Mar 9, 2015 | 12:48 PM
robb1887's Avatar
bump!
Old Mar 15, 2015 | 03:35 PM
robb1887's Avatar
bump!
Old May 4, 2015 | 01:51 PM
robb1887's Avatar
bump!
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Jonny246
Jul 12, 2015 04:51 AM
akaphilly
Jul 9, 2015 02:34 PM
