Engines - Transmissions Place above type items here
FS[PacSouthWest]: 3VZE Cooling fan with complete shroud used OEM V6
Old Jan 31, 2023 | 10:57 PM
JTR70's Avatar
Good used genuine Toyota cooling fan and shroud. Assembly came out of my 92 Toyota 4WD truck. 150.00+shipping for all.
Fan itself is correct for all V6 trucks, 4Runners and T100's 1988-93
Factory tags still remain on both shrouds.
The main shroud broke at its narrowest point many years ago but once its mounted to the radiator with lower shroud installed it was secured with no issues. Can be JB welded if desired but not necessary.
Shroud is itself is correct for all trucks and 4runners 1990-95
Thanks for looking!
Justin
Old Feb 1, 2023 | 10:05 AM
JTR70's Avatar
Forgot to include this new 3VZE timing belt in the package. So to be clear this listing is for all pictured, Fan/shroud assembly above and this factory timing belt below. 150.00+shipping for all. Thanks for looking.
Old Sep 15, 2023 | 11:50 AM
Cheviac's Avatar
I’m missing the shroud to my 93 t100 , did yours come off a Toyota pick up or t100. I think they are different . I’d be interested in buying this
Old Sep 15, 2023 | 12:33 PM
JTR70's Avatar
Thanks for your interest. This is out of a truck. A T100 shroud is a little wider as is its radiator. The fan and the belt would be the same as long as its a 3VZ motor.
hidesert
May 3, 2017 06:20 PM
Forerunner
10
Nov 24, 2008 01:07 PM
patunga2
Aug 20, 2007 03:38 PM
94toyota4x4
Jan 23, 2007 04:52 PM
Raptor
May 1, 2006 06:02 AM
