Engines - Transmissions Place above type items here
FS[SouthEast]: 22RE Fuel Hose w/Damper
Old May 3, 2018 | 12:17 PM
cikphrek's Avatar
Factory high pressure hose from filter to fuel rail with pulsation dampner. Converted mine to braided hose with AN fittings. Will need new crush washers for install.
Hose factory P/N - 9092301326
Dampner factory P/N - 2327070010
$125 shipped.
Attached Thumbnails 22RE Fuel Hose w/Damper-img_20171130_093311.jpg   22RE Fuel Hose w/Damper-img_20171130_093334.jpg
Old Jan 29, 2020 | 03:20 PM
Rogelio Orozco's Avatar
How did you do the fuel line conversion?
Old Feb 13, 2020 | 01:13 PM
cikphrek's Avatar
I got a fuel rail from LCE that was tapped for AN fittings. Made a braided hose from the filter to the front inlet of the fuel rail with AN6 fittings eliminating the damper. At the other end, removed the FPR from the fuel rail and made a hose going to an adjustable FPR I got off ebay. Think it was an Aeromotive unit. The tricky part is mating up to the solid return line going back to the tank. I think I had to use and AN4 compression fitting, then adapt it to the AN6 coming from the FPR. If it ever stops raining here, I'll try and get you some pics.
Dbaker91
Jul 17, 2019 04:17 AM
shafner30
Sep 19, 2017 06:01 AM
Nirnglaud
Feb 24, 2015 08:58 PM
FuelforWar
Jan 18, 2014 10:49 AM
Ahbustae86
3.4 Swaps
Mar 24, 2011 09:07 PM
