I need a Clutch Hub No.2 (the first hub on the shaft) or a junk W56 that someone would be willing to let go for cheap that's in the Midwest. I broke mine trying to press it on
The image below shows what it is and where its located. The part number is 3336222020.
Thanks.
Do you know if a W46 would have the same part? Trans was from a 1990 2wd pickup that I replaced for a guy. Main bearings are worn but from memory all the gears looked good.
I'm not sure if it would be the same. Are you trying to sell it as a whole or willing to part it out?
