Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
What kind of 220 volt outlet is needed for an air compressor?
Old Feb 26, 2007 | 07:54 PM
Crux's Avatar
I'm pricing out options on a new house and know that I eventually want to run an air compressor and possibly other tools that require a 220volt from the garage (welder?).
Here's the options on the pricing list:
220 Volt Outlet 30 Amp Circuit
220V 50 Amp Circuit w/Disconnect
100 Amp subpanel
110 Dedicated Circuit
110 GFI Outlet
110 Outlet
110V Floor Outlet
Which of these do I need? I don't know nothing about electrical stuff.
Old Feb 26, 2007 | 08:00 PM
wjwerdna's Avatar
the 30amp i believe.... the disconnect would be for something even bigger i think, and permanent...
a separate subpanel would be really nice because from there you could add any needed circuits in the garage, including the 220
the dedicated circuit would be for something like an alarm system maybe, or a clock, or emergency exits/lighting, or anything you don't want to go off, if you blow a circuit
the GFCI would be for anything close or possibly near water, or something that a grounded ext cord could be plugged into that would be near water or outside...
I think thats the basics...
Old Feb 26, 2007 | 09:50 PM
Just Learning's Avatar
if you plan on getting a decent welder i believe 220 50 amp, i sure you will be pointed in the right direction
Old Feb 27, 2007 | 02:53 AM
wjwerdna's Avatar
check around at welder websites, or local welding shops if there are any,,,, they would be able to tell you I am sure
Old Mar 2, 2007 | 09:26 AM
MTL_4runner's Avatar
100 Amp subpanel
Any of these can be wired for 220V, but the last two give you the amperage to run anything. The easiest is probably just to go with #2 since the max the 100 Amp subpanel (assuming it's a 110V incoming line) could be wired for would be the same thing (220V, 50A). Just as an FYI, most well built garages will usually run 100 Amp subpanel AND a 220V outlet (either 30A or 50A.......for most people the 30A is fine even with a large air compressor or welder, but a very large MIG or TIG may need more power) AND a 110V outdoor GFCI outlet.......and that's probably what I would run if I was doing it.
Old Mar 25, 2007 | 06:33 PM
BruceTS's Avatar
Definately a 100 amp subpanel, from there you can add any circuit you need.
Once I finish cleaning up my garage, I'll be wiring in my subpanel, from there a 220v 50a circuit for my TIG welder with slow blow fuses, then a 220v 30a for my compressor and finally a bunch of 110v circuits for the rest.
Old Mar 25, 2007 | 07:14 PM
Lysmachia's Avatar
I love you electricians! I was wondering about this too.
BigArt70
Jun 30, 2015 09:51 PM
yamaha73
Jun 18, 2015 06:19 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
alanh
Jun 25, 2002 04:20 PM
HALMAN
Jun 14, 2002 09:02 PM
